05-19-2015, 15:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Lumia 630 DS no repair boot Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Recovery Handle Found! - (WinUSB) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... Validation is enabled. EMMC: size_in_sectors:15269888, mfr_id:17, oem_id:0, prod_rev:0, mfr_date:9/2014 MSG_HASHTABLE Sent.... MSG_XML_CONFIGURE_\8626_edl_fh_image_config.xml Sent... MSG_XML_PROGRAM_SBL1 Sent... start 53248, num 493 Finished sector address 53741 MSG_XML_PROGRAM_RPM Sent... start 65536, num 302 Finished sector address 65838 MSG_XML_PROGRAM_TZ Sent... start 69632, num 690 Finished sector address 70322 MSG_XML_PROGRAM_UEFI Sent... start 61440, num 2229 Finished sector address 63669 MSG_XML_PROGRAM_WINSECAPP Sent... start 73728, num 538 Finished sector address 74266 MSG_XML_PROGRAM_TZAPPS Sent... start 77824, num 1070 Finished sector address 78894 MSG_XML_PROGRAM_DBI Sent... start 57344, num 36 Finished sector address 57380 MSG_XML_ERASE_DDR Sent... start 36864, num 32 Finished address 36896 MSG_XML_ERASE_PLAT Sent... start 167936, num 16384 Finished address 184320 MSG_XML_ERASE_EFIESP Sent... start 184320, num 65536 Finished address 249856 MSG_XML_PROGRAM_8626_gpt_v1_0.bin Sent... start 0, num 34 Finished sector address 34 MSG_XML_POWER Sent... Firehose Payload All Sent! Waiting for USB Cycle... USB Cycle OK! Rebooting Phone... ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== ================================================== ==== ERROR: Flashing Failed! |
05-20-2015, 02:47 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | From the logs it shows Phone boot already repaired by atf, but your phone battery is empty. So just charge battery with external charger or by using another phone which is not dead. Then put charged battery back to dead phone and it will flash normally. P.S. Boot repair just need usb cable for lumia 630. It does not use battery |
