08-03-2016, 02:19 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | lumia 630 rm-978 dead boot |
The Following User Says Thank You to elpring For This Useful Post: |
08-04-2016, 06:48 | #4 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | after try flash now phone not detected 9008 this is log of flash prosess 42 : ================================================ 10:34:42 : Advance Turbo Flasher Found 10:34:42 : ================================================ 10:34:42 : Driver Version : 00020828 10:34:42 : Library Version : 00030207 10:34:44 : Box Type : ATF Nitro 10:34:44 : Box Firmware : LogiCore 11.0.10 10:34:44 : Software Version : v12.60 10:34:44 : AdvanceBox SN : E7198A7BD09D63EAE3F30AEE 10:34:44 : Box Status : ACTIVATED 10:34:45 : ================================================ 10:34:45 : Box Successfully Initialized 10:34:45 : ================================================ 10:34:45 : 10:34:45 : VBATT Powering Down <<<< 10:34:48 : VBATT Powering Up >>>> 10:34:48 : SET VCCIO Level Done 10:34:48 : SET BSI Load Done 10:34:48 : 10:34:48 : 10:34:48 : 10:34:48 : ///////// /// /// /////// /////// ///////// 10:34:48 : /// /// /// /// // /// /// /// /// 10:34:48 : /// /// /// /////// /////// /// /// 10:34:48 : /// /// /// /// /// /// /// /// /// 10:34:48 : /// ///// /// /// /////// ////// 10:34:48 : 10:34:48 : ======================================= 10:34:48 : /// /// /// ///////// /////// ////// 10:34:48 : ///// /// /// /// /// // /// /// 10:34:48 : /// ///// /// /// /////// /// /// 10:34:48 : /// //// /// /// /// /// /// /// 10:34:48 : /// /// /// /// /// /// ////// 10:34:48 : ======================================= 10:34:48 : 10:35:26 : ================================================ 10:35:26 : Advance Turbo Flasher Found 10:35:26 : ================================================ 10:35:26 : Driver Version : 00020828 10:35:26 : Library Version : 00030207 10:35:29 : Box Type : ATF Nitro 10:35:29 : Box Firmware : LogiCore 11.0.10 10:35:29 : Software Version : v12.67 10:35:29 : AdvanceBox SN : E7198A7BD09D63EAE3F30AEE 10:35:29 : Box Status : ACTIVATED 10:35:29 : ================================================ 10:35:29 : Box Successfully Initialized 10:35:29 : ================================================ 10:35:29 : 10:35:29 : VBATT Powering Down <<<< 10:35:33 : VBATT Powering Up >>>> 10:35:33 : SET VCCIO Level Done 10:35:33 : SET BSI Load Done 10:35:33 : 10:35:33 : 10:35:33 : 10:35:33 : ///////// /// /// /////// /////// ///////// 10:35:33 : /// /// /// /// // /// /// /// /// 10:35:33 : /// /// /// /////// /////// /// /// 10:35:33 : /// /// /// /// /// /// /// /// /// 10:35:33 : /// ///// /// /// /////// ////// 10:35:33 : 10:35:33 : ======================================= 10:35:33 : /// /// /// ///////// /////// ////// 10:35:33 : ///// /// /// /// /// // /// /// 10:35:33 : /// ///// /// /// /////// /// /// 10:35:33 : /// //// /// /// /// /// /// /// 10:35:33 : /// /// /// /// /// /// ////// 10:35:33 : ======================================= 10:35:33 : 10:35:58 : 10:35:58 : ================================================== ==== 10:35:58 : Selected VPL File: 10:35:58 : RM978_059V9N3_02040.00021.15235.50006_042.vpl 10:35:58 : ================================================== ==== 10:35:58 : Variant Details : RM-978 VAR IMEA 9L CV 10:35:58 : Software Version : 02040.00021.15235.50006 10:35:58 : Product Type : RM-978 10:35:58 : Product Code : 059V9N3 10:35:58 : Variant Version : 042 10:35:58 : 10:36:01 : Windows Phone 8/8.1/10 Flashing Started 10:36:01 : Loading Flash Files Please Wait... 10:36:02 : 10:36:02 : [DEAD BOOT REPAIR via USB is SUPPORTED] 10:36:02 : 10:36:02 : ================================================== ==== 10:36:02 : Windows Phone 8/8.1/10 Lumia Flasher 10:36:02 : ================================================== ==== 10:36:02 : 10:36:02 : If the Phone is ALIVE 10:36:02 : 1. Power On the Phone and Connect it to the USB Port 10:36:02 : 10:36:02 : If the Phone is DEAD 10:36:02 : 1. Connect Phone to the USB Port 10:36:02 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 10:36:02 : 3. Wait until the Phone Vibrates Shortly... 10:36:02 : 4. Stop Pressing the Buttons... 10:36:02 : 10:36:02 : If the Phone is DEAD BOOT 10:36:02 : 1. Connect Phone to the USB Port 10:36:02 : 2. Install Correct Drivers: 10:36:02 : "Nokia Emergency Connectivity" Located at: 10:36:02 : 10:36:02 : C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ 10:36:02 : ================================================== ==== 10:36:02 : 10:36:23 : Recovery Handle Found! - (Qualcomm) 10:36:24 : PBL Emergency Download Detected 10:36:24 : 10:36:24 : Start Sending Firehose Loader... 10:36:25 : Firehose Loader Sent! 10:36:25 : Executing Firehose Loader... 10:36:26 : Start Processing Firehose Payload... 10:36:26 : MSG_SIGNATURE Sent.... 10:36:26 : Validation is enabled. 10:36:26 : MSG_HASHTABLE Sent.... 10:36:26 : MSG_XML_CONFIGURE_\8626_edl_fh_image_config.xml Sent... 10:36:26 : MSG_XML_PROGRAM_SBL1 Sent... 10:36:26 : start 53248, num 493 10:36:27 : Finished sector address 53741 10:36:27 : MSG_XML_PROGRAM_RPM Sent... 10:36:27 : start 65536, num 302 10:36:27 : Finished sector address 65838 10:36:27 : MSG_XML_PROGRAM_TZ Sent... 10:36:27 : start 69632, num 690 10:36:27 : Finished sector address 70322 10:36:27 : MSG_XML_PROGRAM_UEFI Sent... 10:36:27 : start 61440, num 2229 10:36:28 : Finished sector address 63669 10:36:28 : MSG_XML_PROGRAM_WINSECAPP Sent... 10:36:28 : start 73728, num 538 10:36:28 : Finished sector address 74266 10:36:28 : MSG_XML_PROGRAM_TZAPPS Sent... 10:36:28 : start 77824, num 1070 10:36:28 : Finished sector address 78894 10:36:28 : MSG_XML_PROGRAM_DBI Sent... 10:36:28 : start 57344, num 36 10:36:28 : Finished sector address 57380 10:36:28 : MSG_XML_ERASE_DDR Sent... 10:36:28 : start 36864, num 32 10:36:28 : MSG_XML_ERASE_PLAT Sent... 10:36:28 : start 167936, num 16384 10:36:28 : Finished address 184320 10:36:28 : MSG_XML_ERASE_EFIESP Sent... 10:36:28 : start 184320, num 65536 10:36:29 : Finished address 249856 10:36:29 : MSG_XML_PROGRAM_8626_gpt_v1_0.bin Sent... 10:36:29 : start 0, num 34 10:36:29 : Finished sector address 34 10:36:29 : MSG_XML_POWER Sent... 10:36:29 : 10:36:29 : Firehose Payload All Sent! 10:36:29 : Waiting for USB Cycle... 10:36:29 : USB Cycle OK! 10:36:29 : Rebooting Phone... 10:37:29 : 10:37:29 : ================================================== ==== 10:37:29 : ERROR: Active Phone Handle was NOT DETECTED |
08-04-2016, 06:52 | #5 (permalink) |
08-04-2016, 07:16 | #7 (permalink) |
No Life Poster Join Date: Nov 2013 Location: World Age: 29
Member: 2058871 Status: Offline Sonork: 100.1664591 Thanks Meter: 206 | hi Men, wait, i'm uploading edit http://www.4shared.com/rar/nYL4f2N3b...r_another.html please push thanks buttom Last edited by mtk6572s4clone; 08-04-2016 at 07:26. |
The Following User Says Thank You to mtk6572s4clone For This Useful Post: |
08-04-2016, 08:21 | #11 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E |
