Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-05-2013, 15:13   #1 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
lumia 710 boot repair done... But Cannot Flash - (BOOT FILES INSIDE) < SOLVED >
phone comes fully dead to me,Repair boot via TP and boot repair Succes and phone start vibrate only
Uploaded with ImageShack.us
So i did scan partitions and Restore dload mode and trying to flash phone but always getting error
Here is File Varification
        Flash File Checksum Verification
RM803_12w46_prod_generic_nokia_osbl.esco: CHECKSUM PASSED
RM803_12w46_prod_generic_amss.esco: CHECKSUM PASSED
RM803_12w46_prod_generic_adsp.esco: CHECKSUM PASSED
RM803_12460_prod_407_01_boot.esco: CHECKSUM PASSED
RM803_12w46_prod_generic_user_area_erase.esco: CHECKSUM PASSED
Verification Done...
always getting obsl error
Windows Phone Flashing Started
OSBL File Found:
AMSS File Found:
ADSP File Found:
WPOS File Found:
USER AREA ERASE File Found:
             Windows Phone Lumia Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Press and Hold the VOLUME UP button
  2. Connect it to the USB Port while still Pressing
  3. Continue to Press the VOLUME UP button for 8 more
     seconds
Sending OSBL Certificate
HASH: C72DBA3ABED42215584093FA9DE247381D6062B4
Certificate Size: 452 Bytes
ERROR: Data Rejected at SEQ 0x3
Status     : WRITE OSBL CERTIFICATE FAILED
battery is fully charged, and phone pcb is clean, there is no hardware issue,
please help me to revive this Unit.
The Following User Says Thank You to himanshu taldar For This Useful Post:
Old 06-06-2013, 11:46   #2 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
still waiting for reply from product supporters.
Old 06-06-2013, 16:57   #3 (permalink)
Member: 1263622
Thanks Meter: 149
i have same problem "lumia 800" plz help atf team.................. i wait for your good reply with any good tested solution.
Old 06-07-2013, 06:13   #4 (permalink)
Member: 823432
Thanks Meter: 13
i have a lumia 710 dead too, i post many days ago and i dont have answer form atf team, i think we have to try back a life by us i cant still waiting for they. So many nokia lumia dead by this box and a littel reply from they
Old 06-07-2013, 08:19   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
How to Restore OSBL DLOAD for Lumia 710 only:
  • Select Model from Windows Phone tab
  • Go to "eMMC Direct" tab
  • Press VOL UP and connect USB cable to powered off phone
  • Click on "Scan Partitions"
  • Click on "Restore DLOAD"
Now phone will be able to take flashing by ATF or any othe Nokia software....
http://forum.gsmhosting.com/vbb/9297451-post27.html
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 06-07-2013, 08:21   #6 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
http://forum.gsmhosting.com/vbb/9483602-post5.html
Br - srinibas
Old 06-07-2013, 09:26   #7 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Br - srinibas
sir, for your kind information, please read my post two,three, four or may be more times, until you understand, what i am trying to say, as you can see, after boot repair my phone is already detected via ATF box, and i am facing error while flashing my phone, there is no detection problem
look logs here
Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes  ERROR: Data Rejected at SEQ 0x3 Status     : WRITE OSBL CERTIFICATE FAILED
i hope you understand there is no detection problem, here is problem during write image to phone, and it is not only with me, look most of the Lumia threads in your section, you will find simmiler issue.so i need good and working solution.
Old 06-07-2013, 09:40   #8 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
look logs here
Brother Himansu
Have you follow this - http://forum.gsmhosting.com/vbb/9483602-post5.html
Do it & post result
Br - srinibas
Old 06-07-2013, 09:55   #9 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Brother Himansu
Do it & post result
Br - srinibas
Sir , already follow this, thats why i am able to conect my phone for flash. but getting this error
Phone is already in Dload mode, thats why i am able to detect it ATF and any other nokia software, but not able to flash.
Old 06-08-2013, 14:22   #10 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
still waiting for help from P/s & P/M?
Old 06-08-2013, 14:55   #11 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,117
Put QCOM OSBL to your phone via dead boot repair procedure.
After putting QCOM, check phone is now detected as an external hard drive when connected to usb port and volume up button is pressed.
If detected ok, then eMMC direct tab in atf should be able to detect the phone as well.
So make backup of phone first, then i will upload RAW binary files for you to manually write on partitions.
Btw, what RM-XXx is your phone.
Old 06-08-2013, 23:35   #12 (permalink)
Member: 823432
Thanks Meter: 13
Hello Mr Avance-Box am tray many days ago contact with you because i have a lumia 710 RM-809 dead too, i pass PM and you dont answer me yet, i need your help because i need to fix as soon as possible the cel. The cel is dead completly, the pc no recognice the phone, no vibrate in others words is fully dead. When i try to repair the boot doit all ok, just there. Plz help me.
Old 06-08-2013, 23:44   #13 (permalink)
Member: 651945
@yendry07
Do same as post # 11
Old 06-10-2013, 09:53   #14 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
My phone is rm-803 nokia 710
boot fixed again via tp and put on qcom osbl mode
and now its detected as emmc
back up all the partitons
already save all backup.
and i have a question now, i have another lumia 710 with same Rm type. can i write this phone partitions to dead phone? if not
waiting for your raw Binary files.
Old 06-10-2013, 16:29   #15 (permalink)
Member: 1263622
Thanks Meter: 149
Arrow
this solution not working for me.......................
Page generated in 0.21102 seconds with 8 queries
