06-11-2013, 04:29 | #16 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Hi, good job! It seems you fully understood what I said. Now all you have to do is download my 710 plain binary repair files (for eMMC Direct) and write it one by one to your phone. WARNING: After writing the 3 files to your phone, your phone will be back to NOKIA DLOAD OSBL again, so you need to flash the phone via USB (regular flashing) in order to fully fix it. Download here: http://174.120.45.27/tmp/710_RM803_R...BOOT_FILES.rar What's Inside that RAR file??? 1. dbl.bin <--- Write this to 0x4D - DBL Partition 2. osbl_nokia.bin <--- Write this to 0x46 - OSBL Partition 3. amss_adsp.bin <--- Write this to 0x0C - AMSS_ADSP Partition You need to write 1 by 1 VIA eMMC Direct as it is not possible to write them together. Follow 1-2-3 in correct sequence. Anyway, check if you can now flash your phone after writing those 3 files... If you still cannot flash it, then post error LOGS here. It is possible that your partitions needs "re-allignment". B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-11-2013, 08:38 | #17 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | @ X-Shadow... superb support sir, Written all 3 Partitions One by One as suggesetd By you. Uploaded with ImageShack.us and after that a long Vibrate and here is the result Uploaded with ImageShack.us Phone is fully Fixed now.. i dont flash this phone, because i previuously flashed thia phone in EMMC mode by Rainbowmod 2.1 Custom Firmware. so No need to Flash again. Thank for your quick help BR |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
06-12-2013, 07:55 | #18 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | Quote:
Dear sir,my lumia 800 was same problem but where found boot file? plz give me boot file for lumia 800 rm-801. http://forum.gsmhosting.com/vbb/f609...6/#post9494510 | |
06-12-2013, 12:43 | #19 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Quote:
Until then, please, be patient. BR | |
06-15-2013, 04:41 | #20 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
SOLUTION for Lumia 800 Already Posted Here: http://forum.gsmhosting.com/vbb/f609...epair-1673102/ | |
06-17-2013, 12:14 | #23 (permalink) |
Freak Poster Join Date: Sep 2001 Location: ASIA
Member: 6569 Status: Offline Thanks Meter: 15 | Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000080000000 4D00000001000000E80300000000000046000000E9030000B8 0B0000000000000C000000A10F0000E0930400000000000500 000081A304007F9CE20055AA55CF8FFF Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 0017B7BE Protection Information Write Protect A: OFF Write Protect B: OFF Writing MBR... Write Success! Writing DBL... Write Success! Writing OSBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:01:38 and after scanning it shows FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 1 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 only this three patitions .. thanks in advance gsmsharing |
06-17-2013, 13:16 | #25 (permalink) |
Member: 6569 Status: Offline Thanks Meter: 15 | i mean to say i don't get partitions such as 0xEF- PMM 0x58- ENC_STORAGE_A 0x4A-ENC_STORAGE_B 0X4B-ENC_STORAGE_C 0X48-WP_OS as every body else do get while scan partitions I HAVE ALREADY WRITTEN 3 PATITIONS (BOOT FILES GIVEN BY ADVANCE BOX) and is this the cause of not getting 710 ON THANKS IN ADVANCE GSMSHAING |
06-17-2013, 13:20 | #26 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | @gsmsharing - how to repair dead lumia phones - after boot is repaired with OSBL DLOAD ticked and other too, then full flash phone. If you get an error, then post it here. BR |
06-17-2013, 13:30 | #27 (permalink) | |
Member: 6569 Status: Offline Thanks Meter: 15 | Quote:
AFTER BOOT RPAIRED WITH OSBL DLOAD TICKED, DURING FLASHING I GET ERROR AS BELOW, WITH FULL CHARGED BATTERY Windows Phone Flashing Started OSBL File Found: RM803_12w46_prod_generic_nokia_osbl.esco AMSS File Found: RM803_12w46_prod_generic_amss.esco ADSP File Found: RM803_12w46_prod_generic_adsp.esco WPOS File Found: RM803_12460_prod_221_01_boot.esco USER AREA ERASE File Found: RM803_12w46_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED | |
06-18-2013, 00:12 | #28 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @gsmsharing You have a unalligned Windows Phone partition possibly due to an incorrect custom firmware flashing. You can still fix your phone, but only if your imei and simlocks are still available. The only way to do this is manually... You need to put QCOM OSBL to your phone and use HxD hex editor to save the entire dump of your phone into a file. Then you need to compress this file via WinRAR and then upload the compressed file somewhere for me to download and search for the imei and simlocks. |
06-18-2013, 06:22 | #29 (permalink) | |
gsmsharing | |
12-05-2013, 19:33 | #30 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India Ranchi
Member: 756180 Status: Offline Sonork: 100.1582554 Thanks Meter: 56 | Quote:
