02-05-2013, 14:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Gujrat (India) Age: 38
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | lumia 710 dead after format how can i repair it? if phone not detach via usb Can i repair this with ATF via Testpoint? |
02-05-2013, 14:24 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, yes, you can! 1. Solder JTAG wires to your lumia 2. Repair boot-loader from "TP Services" tab. 2.1 Tick on "MBR, SEC_BOOT and OSBL DLOAD" and Repair Boot 3. After boot-loader is repaired, flash with your desire version in DEAD Mode. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
02-05-2013, 14:59 | #4 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 00628685 Protection Information Write Protect A: OFF Write Protect B: OFF |
02-05-2013, 15:00 | #5 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 00628685 Protection Information Write Protect A: OFF Write Protect B: OFF Writing MBR... Write Success! Writing SEC_BOOT... ERROR: Block Write Failed at 0x00000001 Check your Test Point Soldering! ERROR: WRITE FAILED! Total Elapsed Time 00:00:02 |
02-05-2013, 15:07 | #6 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | boot repair done after update atf update file online ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 00628685 Protection Information Write Protect A: OFF Write Protect B: OFF Writing MBR... Write Success! Writing SEC_BOOT... Write Success! Writing OSBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:01:39 |
02-05-2013, 15:24 | #8 (permalink) |
Member: 253882 Status: Offline Sonork: 100.1585698 Thanks Meter: 242 | lumia now poweron complet without flash but i cant update Lumia 710 Windows Phone Flashing Started OSBL File Found: RM803_12w46_prod_generic_nokia_osbl.esco AMSS File Found: RM803_12w46_prod_generic_amss.esco ADSP File Found: RM803_12w46_prod_generic_adsp.esco WPOS File Found: RM803_12460_prod_221_01_boot.esco USER AREA ERASE File Found: RM803_12w46_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ================================================ Basic Phone Information ================================================ SW Version : 1600.3013.8107.11502 IMEI Plain : 359300048344544 HW Version : 112.1402.2.1 Phone Type : RM-803 Product Code : 059M710 Basic Product Code: 059H4J0 Module Code : 0204985 PSN Number : M3K925026 NCSD Version : 1.5 Variant Information: VAR EU GB ORANGE SL BLACK ================================================ Extended Phone Information ================================================ Public ID : FB17E4BA97C4CEC45973345A1A1E1C5A Wireless Lan ID: A0:F4:19:0D:94:46:00:00 Bluetooth ID : A0:F4:19:0C:FF:E1:00:00:00:00:00:00 Rebooting to OSBL MODE ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== |
02-05-2013, 19:28 | #11 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, That's strange when you wrote OSBL DLOAD, it should have changed boot-loader. Anyway, you can also Restore OSBL DLOAD via USB cable for Lumia 710 from eMMC Direct tab. BR |
07-14-2014, 17:35 | #13 (permalink) |
Freak Poster Join Date: Jul 2005 Location: pakistan Age: 44
Member: 166223 Status: Offline Sonork: 100.1587956 Thanks Meter: 36 | lumia 710 dead emmc test point 3 to 4 time but same not connect set how to recover ================================================== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48594E4958205D088343A2 CSD : D04F01320F5903FFFFFFFFEF8A400061 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 7759462400 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB Lumia 710 Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.13 Product SN : 088343A2 Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48594E4958205D088343A2_08A9DC68.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR... Write Success! Writing DBL... Write Success! Writing OSBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:02:14 |
