03-28-2013, 14:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: West Africa Ghana Age: 15
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | Lumia 710 dead boot repair error ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! ERROR: Connection Refused 0x06 Check your Test Point Soldering! |
03-28-2013, 16:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, ATF Software already telling you what is the problem: ERROR: Connection Refused 0x06 Check your Test Point Soldering! BR |
04-06-2013, 10:55 | #4 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Galway Ireland
Member: 1723443 Status: Offline Thanks Meter: 10 | Hi guys im bit new to this but my problem is that i have this lumia 710 that just keeps reboting as far as it goes it to windows logo and than good bye so can you tell me if there is an option that could get it fixed with atf |
04-06-2013, 11:25 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
