12-03-2013, 08:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: >>>JANNAT<<<
Member: 1012319 Status: Offline Thanks Meter: 617 | lumia 710 dead while unlock stap 2 is done after stap 2 pc ask about formet disk drive i formet drive then phone is not power on and not connect in flashing mode |
12-03-2013, 09:05 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @sameer525kk Your phone is killed by you, because you Formatted The Disk. Format means erase everything inside. That is why your phone is dead. Solution is to solder eMMC Testpoints. C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX\710_TP_HIRES.jpg Then Perform Boot Repair via ATF "TP Services" BE VERY CAREFUL in Soldering to those TP AREA. If you are not careful, you will kill phone beyond repair. After doing TP Repair,, unlock phone again! |
