11-05-2013, 10:51 | #1 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2059617 Status: Offline Thanks Meter: 0 | Lumia 710 hardware issue I have currently a problem. My wife's phone (lumia 710) was dead (screen stay on NOKIA) I have some electronics knowledges so I decided to repair it, I buy a ATF nitro + a TP cable for ATF 710. Unfortunetly I did a mistake with the TP cable I destroyed the 2 components where I should do the TP connection (yellow,blue,red) ..... I don't care about the phone, what is important for me is to save the pictures of my children in the phone. Is there any solution to repair it ? what are this 2 components, could I replace it ? Thanks in advance. Chris 5:29:51 : ================================================== ==== 15:29:51 : ================================================== ==== 15:29:51 : eMMC Test Point Connection Module 15:29:51 : ================================================== ==== 15:29:51 : ================================================== ==== 15:29:51 : 15:29:51 : 1. DO NOT USE THE PHONE"S BATTERY 15:29:51 : 2. Connect the Soldered TP Connections to ATF Box 15:29:51 : 3. Disconnect the USB Cable and Wait until the 15:29:51 : the ATF Software will tell you to Connect the USB. 15:29:51 : 15:29:51 : MMC_TP_SEND_CMD: 0200000000A9FF 15:29:51 : MMC_TP_SEND_CMD: 8202FF010191 15:29:51 : MMC_TP_SEND_CMD: 8202FF010191 15:29:51 : 15:29:51 : Interface Reset OK! 15:29:51 : eMMC Supported Voltage Range: 15:29:51 : 3.5-3.6V, 3.4-3.5V, 2.6-2.7V, 2.5-2.6V, 2.4-2.5V 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V, 1.9-2.0V 15:29:51 : MMC_TP_SEND_CMD: 4200000000B2 15:29:51 : ERROR: EMMC_ALL_SEND_CID FAILED (CMD2) 15:29:51 : Check your Test Point Soldering! 15:29:51 : Try to Adjust VCCIO Voltage Last edited by Christopher76; 11-05-2013 at 11:01. |
11-05-2013, 11:40 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, can you post the clear image of phone that shows two damaged components? I will ask X-Shadow if there are other place that can be used for them? BR |
11-05-2013, 12:31 | #4 (permalink) |
Member: 2059617 Status: Offline Thanks Meter: 0 | Hello thank you for your answer but I can't post a link or a picture (not allow for new forum user). The components are the 2 small things perhaps resistor (test point) between hinix and elpida chip. |
