hi to all gsmmasters and advance team
i have lumia 710 which was ok before do any thing that phone came for unlock its lock to t mobile usa
i desire that i do unlock with atf with tp i know that its unlock without tp but i never unlock with tp that's why i decide to unlock with tp
now here is detail step by step what i do plz see and tell me where is my mistake
at first when i want to unlock that error came
PHP Code:
16:46:15 :
16:46:15 : 1. DO NOT USE THE PHONE"S BATTERY
16:46:15 : 2. Connect the Soldered TP Connections to ATF Box
16:46:15 : 3. Disconnect the USB Cable and Wait until the
16:46:15 : the ATF Software will tell you to Connect the USB.
16:46:15 :
16:46:25 :
16:46:25 : Interface Reset OK!
16:46:25 : Reading Platform Information...
16:46:25 : Selecting Active Handle...
16:46:25 : Select Handle OK!
16:46:25 : Sending Ping...
16:46:25 : Ping Reply OK!
16:46:25 :
16:46:25 : Lumia 710 Detected
16:46:25 :
16:46:25 : Storage Device Information
16:46:25 : Manufacturer ID: 90
16:46:25 : Application ID : 014A
16:46:25 : Product Name : HYNIX
16:46:25 : Product Rev : 5D
16:46:25 : Product SN : 005ED62F
16:46:25 :
16:46:25 : Protection Information
16:46:25 : Write Protect A: OFF
16:46:25 : Write Protect B: OFF
16:46:25 :
16:46:34 : ======================================================
16:46:34 : Lumia Test Point Connection Module
16:46:34 :
16:46:34 : 1. DO NOT USE THE PHONE"S BATTERY
16:46:34 : 2. Connect the Soldered TP Connections to ATF Box
16:46:34 : 3. Disconnect the USB Cable and Wait until the
16:46:34 : the ATF Software will tell you to Connect the USB.
16:46:34 :
16:46:36 :
16:46:36 : Interface Reset OK!
16:46:36 : Reading Platform Information...
16:46:36 : Selecting Active Handle...
16:46:36 : Select Handle OK!
16:46:36 : Sending Ping...
16:46:36 : Ping Reply OK!
16:46:36 :
16:46:36 : Lumia 710 Detected
16:46:36 :
16:46:36 : Storage Device Information
16:46:36 : Manufacturer ID: 90
16:46:36 : Application ID : 014A
16:46:36 : Product Name : HYNIX
16:46:36 : Product Rev : 5D
16:46:36 : Product SN : 005ED62F
16:46:36 :
16:46:36 : Protection Information
16:46:36 : Write Protect A: OFF
16:46:36 : Write Protect B: OFF
16:46:36 :
16:46:36 :
16:46:36 : Dumping AMSS FAT16 Region
16:46:36 : Please wait for 2-4 Minutes...
16:46:37 : ======================================================
16:46:37 : Lumia Test Point Connection Module
16:46:37 :
16:46:37 : 1. DO NOT USE THE PHONE"S BATTERY
16:46:37 : 2. Connect the Soldered TP Connections to ATF Box
16:46:37 : 3. Disconnect the USB Cable and Wait until the
16:46:37 : the ATF Software will tell you to Connect the USB.
16:46:37 :
16:46:39 :
16:46:39 : Interface Reset OK!
16:46:39 : Reading Platform Information...
16:46:39 : Selecting Active Handle...
16:46:39 : Select Handle OK!
16:46:39 : Sending Ping...
16:46:39 : Ping Reply OK!
16:46:39 :
16:46:39 : Lumia 710 Detected
16:46:39 :
16:46:39 : Storage Device Information
16:46:39 : Manufacturer ID: 90
16:46:39 : Application ID : 014A
16:46:39 : Product Name : HYNIX
16:46:39 : Product Rev : 5D
16:46:39 : Product SN : 005ED62F
16:46:39 :
16:46:39 : Protection Information
16:46:39 : Write Protect A: OFF
16:46:39 : Write Protect B: OFF
16:46:39 :
16:46:39 :
16:46:39 : Dumping AMSS FAT16 Region
16:46:39 : Please wait for 2-4 Minutes...
16:48:42 : Patch Bit Found...
16:48:42 : Total Patch Bits Found: 1
16:48:42 : Patching AMSS...
16:49:42 : ERROR: Patch Write Failed
16:49:42 : Check your Test Point Soldering!
16:49:42 :
16:49:42 : Total Elapsed Time 00:03:08
then i repeat process
that error come patch bit not found
PHP Code:
16:50:14 : ======================================================
16:50:14 : Lumia Test Point Connection Module
16:50:14 :
16:50:14 : 1. DO NOT USE THE PHONE"S BATTERY
16:50:14 : 2. Connect the Soldered TP Connections to ATF Box
16:50:14 : 3. Disconnect the USB Cable and Wait until the
16:50:14 : the ATF Software will tell you to Connect the USB.
16:50:14 :
16:50:16 :
16:50:16 : Interface Reset OK!
16:50:16 : Reading Platform Information...
16:50:16 : Selecting Active Handle...
16:50:16 : Select Handle OK!
16:50:16 : Sending Ping...
16:50:16 : Ping Reply OK!
16:50:16 :
16:50:16 : Lumia 710 Detected
16:50:16 :
16:50:16 : Storage Device Information
16:50:16 : Manufacturer ID: 90
16:50:16 : Application ID : 014A
16:50:16 : Product Name : HYNIX
16:50:16 : Product Rev : 5D
16:50:16 : Product SN : 005ED62F
16:50:16 :
16:50:16 : Protection Information
16:50:16 : Write Protect A: OFF
16:50:16 : Write Protect B: OFF
16:50:16 :
16:50:16 :
16:50:16 : Dumping AMSS FAT16 Region
16:50:16 : Please wait for 2-4 Minutes...
16:52:21 :
16:52:21 : WARNING: Patch Bit NOT FOUND!
16:52:21 : Maybe Phone is already UNLOCKED!
16:52:21 :
16:52:21 : Total Elapsed Time 00:02:14
then i remove tp and want to power on the phone when phone on its in restarting condition its my problem now
reastarting
now i decide to flash the phone i do flash with best donge
here is detail
PHP Code:
Core : v1.58 , WP7x FlashEngine : v3.5
Flash Files selected :
OSBL : RM803_12w12_2_prod_generic_nokia_osbl.esco
AMSS : RM803_12w12_2_prod_generic_amss.esco
ADSP : RM803_12w12_2_prod_generic_adsp.esco
WP : RM809_12122_prod_277_03_boot.esco
UDA : RM803_12w12_2_prod_generic_user_area_erase.esco
Check files done, All files are Ok
Dead Mode is Selected
Waiting for USB device...
--- Press and hold 'Volume Up' button and insert cable! ---
Connection opened successfully
Establish connection with device...
Init Ok
Boot : 240.116.132.78
==== OSBL ====
Processing : RM803_12w12_2_prod_generic_nokia_osbl.esco
nokia_osbl.mbn.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4
nokia_osbl.mbn , len : 0x000EA228 , Type : Data
Will flash 1 regions
OSBL flashing done
==== AMSS ====
Processing : RM803_12w12_2_prod_generic_amss.esco
amss.mbn.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4
amss.mbn.enc , len : 0x00FDD690 , Type : Data
AMSS flashing done
==== ADSP ====
Processing : RM803_12w12_2_prod_generic_adsp.esco
adsp.mbn.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4
adsp.mbn.enc , len : 0x0055BED0 , Type : Data
ADSP flashing done
==== WINDOWS PHONE ====
Processing : RM809_12122_prod_277_03_boot.esco
boot.img.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4
boot.img , len : 0x17ED6A00 , Type : Data
Will flash 25 regions
Windows Phone flashing done
==== USER DEFINED AREA ====
Processing : RM803_12w12_2_prod_generic_user_area_erase.esco
user_area_erase.cert , Hash : C72DBA3ABED42215584093FA9DE247381D6062B4
UDA file detected, will erase defined region
UDA erase done
UDA flashing done
Flashing done!
Flashing time : 00:03:21
Reboot device Ok
falsh ok but phone in same condition
then i boot repair osbl qcom qualcomm with atf
PHP Code:
20:04:13 : ======================================================
20:04:13 : Lumia Test Point Connection Module
20:04:13 :
20:04:13 : 1. DO NOT USE THE PHONE"S BATTERY
20:04:13 : 2. Connect the Soldered TP Connections to ATF Box
20:04:13 : 3. Disconnect the USB Cable and Wait until the
20:04:13 : the ATF Software will tell you to Connect the USB.
20:04:13 :
20:04:22 :
20:04:22 : Interface Reset OK!
20:04:22 : Reading Platform Information...
20:04:22 : Selecting Active Handle...
20:04:22 : Select Handle OK!
20:04:22 : Sending Ping...
20:04:22 : Ping Reply OK!
20:04:22 :
20:04:22 : Lumia 710 Detected
20:04:22 :
20:04:22 : Storage Device Information
20:04:22 : Manufacturer ID: 90
20:04:22 : Application ID : 014A
20:04:22 : Product Name : HYNIX
20:04:22 : Product Rev : 5D
20:04:22 : Product SN : 005ED62F
20:04:22 :
20:04:22 : Protection Information
20:04:22 : Write Protect A: OFF
20:04:22 : Write Protect B: OFF
20:04:22 :
20:04:22 : Writing MBR...
20:04:22 : Write Success!
20:04:22 : Writing SEC_BOOT...
20:04:45 : Write Success!
20:04:45 : Writing OSBL...
20:05:51 : Write Success!
20:05:51 :
20:05:51 : BOOT Images Written Successfully!
20:05:51 :
20:05:51 : Total Elapsed Time 00:01:38
boot repair but phone in restart mode now i decide to falsh its own product code then i download files with navefirm and want to falsh but when i do falsh phone not go to flash mode its requierd qualcomm driver i give driver but its not accepted then i decide to boot repair with osbl dload nokia here is detail
PHP Code:
16:03:54 : ======================================================
16:03:54 : Lumia Test Point Connection Module
16:03:54 :
16:03:54 : 1. DO NOT USE THE PHONE"S BATTERY
16:03:54 : 2. Connect the Soldered TP Connections to ATF Box
16:03:54 : 3. Disconnect the USB Cable and Wait until the
16:03:54 : the ATF Software will tell you to Connect the USB.
16:03:54 :
16:03:56 :
16:03:56 : Interface Reset OK!
16:03:56 : Reading Platform Information...
16:03:56 : Selecting Active Handle...
16:03:56 : Select Handle OK!
16:03:56 : Sending Ping...
16:03:56 : Ping Reply OK!
16:03:56 :
16:03:56 : Lumia 710 Detected
16:03:56 :
16:03:56 : Storage Device Information
16:03:56 : Manufacturer ID: 90
16:03:56 : Application ID : 014A
16:03:56 : Product Name : HYNIX
16:03:56 : Product Rev : 5D
16:03:56 : Product SN : 005ED62F
16:03:56 :
16:03:56 : Protection Information
16:03:56 : Write Protect A: OFF
16:03:56 : Write Protect B: OFF
16:03:56 :
16:03:57 : Writing MBR...
16:03:57 : Write Success!
16:03:57 : Writing SEC_BOOT...
16:04:28 : Write Success!
16:04:28 : Writing OSBL...
16:06:09 : Write Success!
16:06:09 :
16:06:09 : BOOT Images Written Successfully!
16:06:09 :
16:06:09 : Total Elapsed Time 00:02:15
boot repair success now phone able to flash and then i flash phone its orignal product code here is detai
PHP Code:
card found: S/N 1F29:0118
registered to: usshad
OSBL : RM803_12w12_prod_generic_nokia_osbl_0605.esco
AMSS : RM803_12w12_prod_generic_amss_0605.esco
ADSP : RM803_12w12_prod_generic_adsp_0605.esco
WP : RM809_12w12_prod_tmous_0605.esco
UDA : RM803_12w12_prod_generic_user_area_erase_0605.esco
Init Ok
==== OSBL ====
Processing : RM803_12w12_prod_generic_nokia_osbl_0605.esco
OSBL flashing done
==== AMSS ====
Processing : RM803_12w12_prod_generic_amss_0605.esco
AMSS flashing done
==== ADSP ====
Processing : RM803_12w12_prod_generic_adsp_0605.esco
ADSP flashing done
Processing : RM809_12w12_prod_tmous_0605.esco
boot.img , len : 0x14E8F800 , Type : Data
Will flash 22 regions
Processing : RM803_12w12_prod_generic_user_area_erase_0605.esco
UDA erase done
UDA flashing done
Flashing done!
Flashing time : 00:02:55
Reboot device Ok
now flash complete but phone in same condition
i also do only amss flash but invain
look brothers masters team members i do everything who my mind say me
can any one tell me where is my mistake and where i am wrong
i appricieate in advance your suggestions
here is video link phone condition
Facebook
