12-13-2013, 14:22 | #1 (permalink) |
Insane Poster Join Date: Jan 2008 Location: Patna,Bihar
Member: 685636 Status: Offline Thanks Meter: 128 | Lumia 710 rm-809 after unlock handset goes to nokia only AFTER UNLOCK MY HANDSET STUCK ON NOKIA ONLY PLS HELP TO RECOVER IN NORMAL CONDITION PLS GIVE ME HELP STEP BY STEP UNLOCK LOG HERE : Only Phoenix.ini Flash Files are 18:09:44 : supported for Checksum Verification... 18:09:46 : Windows Phone Flashing Started 18:09:46 : 18:09:46 : OSBL File Found: 18:09:46 : RM809_OSBL_QUALCOMM.esco 18:09:46 : WARNING: MODEM AMSS File is not Loaded 18:09:46 : WARNING: MODEM ADSP File is not Loaded 18:09:46 : WARNING: WPOS File is not Loaded 18:09:46 : 18:09:46 : ================================================== ==== 18:09:46 : Windows Phone Lumia Flasher 18:09:46 : ================================================== ==== 18:09:46 : 18:09:46 : If the Phone is ALIVE 18:09:46 : 1. Power On the Phone and Connect it to the USB Port 18:09:46 : 18:09:46 : If the Phone is DEAD 18:09:46 : 1. Press and Hold the VOLUME UP button 18:09:46 : 2. Connect it to the USB Port while still Pressing 18:09:46 : the VOLUME UP button 18:09:46 : 3. Continue to Press the VOLUME UP button for 8 more 18:09:46 : seconds 18:09:46 : ================================================== ==== 18:09:46 : 18:10:31 : 18:10:31 : ================================================== ==== 18:10:31 : ERROR: Active Phone Handle was NOT DETECTED 18:10:31 : ================================================== ==== 18:10:31 : 18:10:31 : 18:10:31 : ================================================== ==== 18:12:21 : 18:12:21 : Only Phoenix.ini Flash Files are 18:12:21 : supported for Checksum Verification... 18:12:22 : Windows Phone Flashing Started 18:12:22 : 18:12:22 : OSBL File Found: 18:12:22 : RM809_OSBL_QUALCOMM.esco 18:12:22 : WARNING: MODEM AMSS File is not Loaded 18:12:22 : WARNING: MODEM ADSP File is not Loaded 18:12:22 : WARNING: WPOS File is not Loaded 18:12:22 : 18:12:22 : ================================================== ==== 18:12:22 : Windows Phone Lumia Flasher 18:12:22 : ================================================== ==== 18:12:22 : 18:12:22 : If the Phone is ALIVE 18:12:22 : 1. Power On the Phone and Connect it to the USB Port 18:12:22 : 18:12:22 : If the Phone is DEAD 18:12:22 : 1. Press and Hold the VOLUME UP button 18:12:22 : 2. Connect it to the USB Port while still Pressing 18:12:22 : the VOLUME UP button 18:12:22 : 3. Continue to Press the VOLUME UP button for 8 more 18:12:22 : seconds 18:12:22 : ================================================== ==== 18:12:22 : 18:12:26 : 18:12:26 : ================================================ 18:12:26 : Basic Phone Information 18:12:26 : ================================================ 18:12:27 : SW Version : 1600.3030.8773.12120 18:12:27 : IMEI Plain : 359333042060139 18:12:27 : HW Version : 112.1402.2.1 18:12:28 : Phone Type : RM-809 18:12:28 : Product Code : 059L3Q9 18:12:28 : Basic Product Code: 059L3Q7 18:12:28 : Module Code : 0205040 18:12:29 : PSN Number : MWK375344 18:12:29 : NCSD Version : 1.9 18:12:29 : Variant Information:T-MOBILE BLACK 18:12:29 : 18:12:29 : ================================================ 18:12:29 : Extended Phone Information 18:12:29 : ================================================ 18:12:30 : Public ID : 076E5F6638FADA3545BB0757272ADAA6 18:12:31 : Wireless Lan ID: 50:2D:1D:69:C6:58:00:00 18:12:31 : Bluetooth ID : 50:2D:1D:69:2A:25:00:00:00:00:00:00 18:12:31 : 18:12:34 : Rebooting to OSBL MODE 18:12:39 : 18:12:39 : Sending OSBL Certificate 18:12:39 : HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 18:12:39 : Certificate Size: 452 Bytes 18:12:39 : Status : WRITE OSBL CERTIFICATE SUCCESS 18:12:39 : 18:12:39 : Sending OSBL Data Blocks 18:12:39 : [BLOCK 1 0x00000000~0x000D5227] 18:12:39 : Data Size: 0x000D5228 Bytes 18:12:39 : SHA-256 : C603E58395ED18036FAE54480980C874 18:12:39 : ---------- : 730B725073658C1DA8123C9B639F625A 18:12:40 : Status : OSBL WRITE SUCCESS 18:12:40 : 18:12:40 : Flashing Done! 18:12:40 : Total Flashing Time (Erase + Flashing) : 00:00:01 18:13:01 : ERROR: Select Correct Phone Type! 18:13:01 : 18:13:01 : Total Elapsed Time 00:00:00 18:13:11 : ================================================== ==== 18:13:11 : ================================================== ==== 18:13:11 : eMMC Test Point Connection Module 18:13:11 : ================================================== ==== 18:13:11 : ================================================== ==== 18:13:11 : 18:13:11 : 1. DO NOT USE THE PHONE"S BATTERY 18:13:11 : 2. Connect the Soldered TP Connections to ATF Box 18:13:11 : 3. Disconnect the USB Cable and Wait until the 18:13:11 : the ATF Software will tell you to Connect the USB. 18:13:11 : 18:13:17 : ERROR: EMMC WAS NOT Detected! (CMD1) 18:13:17 : Check your Test Point Soldering! 18:13:17 : CMD1 Reply: 0x5E5E5E5E 18:13:17 : 18:13:17 : Total Elapsed Time 00:00:06 18:23:05 : ================================================== ==== 18:23:06 : ================================================== ==== 18:23:06 : eMMC Test Point Connection Module 18:23:06 : ================================================== ==== 18:23:06 : ================================================== ==== 18:23:06 : 18:23:06 : 1. DO NOT USE THE PHONE"S BATTERY 18:23:06 : 2. Connect the Soldered TP Connections to ATF Box 18:23:06 : 3. Disconnect the USB Cable and Wait until the 18:23:06 : the ATF Software will tell you to Connect the USB. 18:23:06 : 18:23:12 : ERROR: EMMC WAS NOT Detected! (CMD1) 18:23:12 : Check your Test Point Soldering! 18:23:12 : CMD1 Reply: 0x5E5E5E5E 18:23:12 : 18:23:12 : Total Elapsed Time 00:00:06 18:23:22 : 18:23:23 : FOUND: Qualcomm MMC Storage USB Device 18:23:23 : Mounted Drive Number: 3 18:23:23 : 18:23:23 : MBR Entry[0]: 18:23:23 : Flags : 128 18:23:23 : Type : 0x4D - DBL 18:23:23 : Starting Sector: 0x00000001 18:23:23 : Sector Count : 0x000003E8 18:23:23 : MBR Entry[1]: 18:23:23 : Flags : 0 18:23:23 : Type : 0x46 - OSBL 18:23:23 : Starting Sector: 0x000003E9 18:23:23 : Sector Count : 0x00000BB8 18:23:23 : MBR Entry[2]: 18:23:23 : Flags : 0 18:23:23 : Type : 0x0C - AMSS_ADSP 18:23:23 : Starting Sector: 0x00000FA1 18:23:23 : Sector Count : 0x000493E0 18:23:23 : EBR Entry[0]: 18:23:23 : Flags : 0 18:23:23 : Type : 0xEF - PMM 18:23:23 : Starting Sector: 0x0004A386 18:23:23 : Sector Count : 0x00000080 18:23:23 : EBR Entry[1]: 18:23:23 : Flags : 0 18:23:23 : Type : 0x58 - ENC_STORAGE_A 18:23:23 : Starting Sector: 0x0004A406 18:23:23 : Sector Count : 0x00001800 18:23:23 : EBR Entry[2]: 18:23:23 : Flags : 0 18:23:23 : Type : 0x4A - ENC_STORAGE_B 18:23:23 : Starting Sector: 0x00060000 18:23:23 : Sector Count : 0x00001800 18:23:24 : EBR Entry[3]: 18:23:24 : Flags : 0 18:23:24 : Type : 0x4B - ENC_STORAGE_C 18:23:24 : Starting Sector: 0x00061800 18:23:24 : Sector Count : 0x00001800 18:23:24 : EBR Entry[4]: 18:23:24 : Flags : 0 18:23:24 : Type : 0x48 - WP_OS 18:23:24 : Starting Sector: 0x00080000 18:23:24 : Sector Count : 0x00E10FFF 18:23:24 : 18:23:24 : 18:23:24 : 18:23:24 : Dumping AMSS FAT16 Region 18:23:24 : Please wait for 15-20 Seconds... 18:23:47 : Patch Bit Found... 18:23:48 : Total Patch Bits Found: 1 18:23:48 : Patching AMSS... 18:23:48 : 18:23:48 : 18:23:48 : SP Unlock Done! 18:23:48 : 18:23:48 : PIN: 00000000 18:23:48 : PUK: 0000000000 18:23:48 : 18:23:48 : Total Elapsed Time 00:00:26 |
12-14-2013, 08:40 | #2 (permalink) | |
Member: 685636 Status: Offline Thanks Meter: 128 | Atf team waiting your reply .....must reply Quote:
atf team must reply i am waiting your reply | |
12-14-2013, 09:12 | #3 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 727810 Status: Offline Sonork: 100.1627301 Thanks Meter: 167 | did u try hard reset , just try then post result , by pressing vol down + camera +power on button , at the same time , when phone vibrate just release power button , bt keep pressing other two button until u see window phone... |
