10-10-2012, 11:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: EU Age: 44
Member: 60809 Status: Offline Thanks Meter: 28 | Lumia 710 test connection problem All soldering poit ok! Code: ====================================================== ====================================================== Lumia Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. -----Connect USB cable to phone PCB----- (I connect the usb) -----Target Detected!----- ERROR: Phone WAS NOT Detected! 0x01 Check your Test Point Soldering! What do I not correctly? |
