03-12-2014, 12:13 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | lumia 710 un-alligned CWF ! 1- LOG CHECK TEST POINT ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 90014A48594E4958205D003EC8C9 CSD : D04F01320F5903FFFFFFFFEF8A400061 eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 710 Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.13 Product SN : 003EC8C9 Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO 2 LOG REPAIR BOOT ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V CID : 90014A48594E4958205D003EC8C9 CSD : D04F01320F5903FFFFFFFFEF8A400061 eMMC Boot Information BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED Lumia 710 Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.13 Product SN : 003EC8C9 Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Writing MBR... Write Success! Writing DBL... Write Success! Writing OSBL... Write Success! BOOT Images Written Successfully! Total Elapsed Time 00:02:13 3-LOG FOR READ PARTITION AFTER WRITE BOOTS FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 5 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x00E10FFF And after write row boots and WP_OS my fone vibrate Only and i try flash whith atf software and show-me this error: ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED But NOW a re-write boot files ( repair boot) and my phone is qualcomm . i need your know-how atf team! |
03-12-2014, 12:31 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Bruno Rafael This means your keystore is damaged... So you must WRITE QUALCOMM OSBL to your phone and from now you can only flash your phone using eMMC Direct Tab via Qualcomm Loader. Make sure you write all partitions 1 by 1 then write partition 0x48 - WP_OS using esco flash file "boot"... (this is the biggest flash file about 300+ MB). Then if done correctly, your phone will power UP correctly. |
03-14-2014, 00:25 | #6 (permalink) | |
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | Quote:
scan partition: FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 5 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x00E10FFF write DBL Loading Partition File: B:\ATF BOX\RM-803_RM-809_BOOTS_RAW (1)\RM-803_RM-809_BOOTS_RAW\dbl_RM-803_RM-809.bin Writing Partition 0x4D Partition 0x4D Write OK Total Elapsed Time 00:00:00 Write OSBL Loading Partition File: B:\ATF BOX\RM-803_RM-809_BOOTS_RAW (1)\RM-803_RM-809_BOOTS_RAW\osbl_nokia_RM-803_RM-809.bin Writing Partition 0x46 Partition 0x46 Write OK Total Elapsed Time 00:00:00 write amss Loading Partition File: B:\ATF BOX\RM-803_RM-809_BOOTS_RAW (1)\RM-803_RM-809_BOOTS_RAW\amss_adsp_RM-803_RM-809.bin Writing Partition 0x0C Partition 0x0C Write OK Total Elapsed Time 00:00:28 write WP_OS Loading Partition File: B:\ATF BOX\Products\RM-809\RM803_12070_prod_231_03_boot.esco Writing Partition 0x48 Partition 0x48 Write OK Total Elapsed Time 00:01:33 Phone ONLY VIBRATE... as I said before .... the phone only vibrates after every procedure and does not run flash! and now? | |
03-14-2014, 13:56 | #8 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Same problem with me bro....TEAM SOLVE THIS PROBLEM.....EVERY ONE SRUCK http://forum.gsmhosting.com/vbb/f609...epair-1790215/ |
