10-27-2015, 16:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 57
Member: 137980 Status: Offline Thanks Meter: 168 | lumia 710 unlock errror Make sure your are running AdvanceBox.exe with Administrator Priviledges ================================================== ==== How To Run AdvanceBox.exe "as administrator" ================================================== ==== 1. Close ATF Software 2. Goto C:\AdvanceBox Turbo Flasher\ 3. Right-Click Mouse on File AdvanceBox.exe 4. Select "Run as administrator" Maybe your Phone is not running QCOM OSBL ================================================== ==== How To Enter Qualcomm MMC Storage Mode ================================================== ==== 1. Power OFF the Phone 2. Press and HOLD Volume UP Button on the Phone 3. Connect USB Cable to Phone Maybe your Phone is does not have QCOM OSBL ??? ================================================== ==== How To Put QCOM OSBL into the Phone ================================================== ==== 1. Lumia 710 - VIA USB Flashing 2. Lumia 800 - VIA TP Boot Repair 3. Other Lumia Models are NOT SUPPORTED ERROR: AMSS Partition Not Found how to fix also there is option show dick not formated format or cencel ?which option i use ? |
10-28-2015, 06:06 | #2 (permalink) |
Member: 137980 Status: Offline Thanks Meter: 168 | still waiting Make sure your are running AdvanceBox.exe with Administrator Priviledges ================================================== ==== How To Run AdvanceBox.exe "as administrator" ================================================== ==== 1. Close ATF Software 2. Goto C:\AdvanceBox Turbo Flasher\ 3. Right-Click Mouse on File AdvanceBox.exe 4. Select "Run as administrator" Maybe your Phone is not running QCOM OSBL ================================================== ==== How To Enter Qualcomm MMC Storage Mode ================================================== ==== 1. Power OFF the Phone 2. Press and HOLD Volume UP Button on the Phone 3. Connect USB Cable to Phone Maybe your Phone is does not have QCOM OSBL ??? ================================================== ==== How To Put QCOM OSBL into the Phone ================================================== ==== 1. Lumia 710 - VIA USB Flashing 2. Lumia 800 - VIA TP Boot Repair 3. Other Lumia Models are NOT SUPPORTED ERROR: AMSS Partition Not Found |
10-28-2015, 06:54 | #3 (permalink) |
Member: 137980 Status: Offline Thanks Meter: 168 | unlock with other box in few seconds State : Not Patched Patch ... Patch Ok Unlock Code (PIN) : 00000000 Unlock Code (PUK) : 0000000000 1. Power Up phone 1.0 Press Restart button 1.1 Or Reconnect Battery / 15sec. hold PowerOn, after PowerOn 2. Enter code (PIN or PUK) 3. After PIN/PUK accepted, you can restore state via "Restore SimLock state" (c) Wp7x Patch Unlock : Bph&co (Genie Projects) All done! Lumia eMMC drive disconected! Connect phone on selected interface... |
11-14-2015, 10:38 | #4 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | ERROR: Qualcomm MMC Storage is NOT FOUND Make sure your are running AdvanceBox.exe with Administrator Priviledges ================================================== ==== How To Run AdvanceBox.exe "as administrator" ================================================== ==== 1. Close ATF Software 2. Goto C:\AdvanceBox Turbo Flasher\ 3. Right-Click Mouse on File AdvanceBox.exe 4. Select "Run as administrator" Maybe your Phone is not running QCOM OSBL ================================================== ==== How To Enter Qualcomm MMC Storage Mode ================================================== ==== 1. Power OFF the Phone 2. Press and HOLD Volume UP Button on the Phone 3. Connect USB Cable to Phone Maybe your Phone is does not have QCOM OSBL ??? ================================================== ==== How To Put QCOM OSBL into the Phone ================================================== ==== 1. Lumia 710 - VIA USB Flashing 2. Lumia 800 - VIA TP Boot Repair 3. Other Lumia Models are NOT SUPPORTED |
11-14-2015, 10:40 | #5 (permalink) | |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Quote:
which other box did you use ? | |
01-12-2016, 16:27 | #6 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | I am getting the same error on 2 PC I have used before. Any recommendation? Edit: I just used an old NssPro version I had and this was the result: Code: ---------------------------------------------------- Looking for phone...Not found! Can't read IMEI, backup will be skipped. ---------------------------------------------------------------------------- Looking for NAND disk...Done. Trying to parse partition tables...Done. ---------------------------------------------------- FAT16 absolute address: 0x001F4200 FAT16 partition size: 0x0927C000 ---------------------------------------------------- Reading FAT16 raw...Done. Searching locations...Done. Found 1 locations to modify, processing: Reading sector 0...Done. Modify sector...Done. Updating sector...Done. Modification written. Please follow those steps: 1. Disconnect USB cable and remove the battery 2. Insert not supported simcard and power on the phone 3. If asked for PIN code, enter 00000000 4. If asked for PUK code, enter 0000000000 5. After unlock success, connect to USB, enter OSBL mode 6. Press Unlock again to restore the phone to original Last edited by y3kt; 01-12-2016 at 16:32. |
01-12-2016, 16:40 | #7 (permalink) |
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | More on this. I just used and old executable of version 11.70 and phone was detected as well. Code: FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 3 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x00E10FFF Dumping AMSS FAT16 Region Please wait for 15-20 Seconds... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:22 Luck! |
