Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-10-2013, 17:14   #1 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Lumia 710 unlock problem...
Step 3 flash.....Ok!
Step 3 Unlock:error.....AMSS Partition Not Found
Basic Phone Information
SW Version : 1600.3031.8773.12121
IMEI Plain : 3...............9
HW Version : 112.1402.2.1
Phone Type : RM-803
Product Code : 059N2Q4
Basic Product Code: 059H4J0
Module Code : 0204985
PSN Number : MQO531364
NCSD Version : 1.9
Variant Information: VAR EU HU T-MOBILE SL BLACK
The problem is that you can not join OSBL mode???
The Device Manager shows:
ALCATEL HS_USB Diagnostics 9006 /COM11/
When I connect the volume plus pressure.....this is a driver Sigmabox!!
Alcatel see why????
What is the solution to this?
Old 12-10-2013, 17:16   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
1. Restore DLOAD from eMMC Direct Tab
2. Flash Phone with latest version
3. Follow unlock instructions again
Old 12-10-2013, 21:11   #3 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Driver will be a problem.....
If I connect OSBL mode /volume + press and connect/....in device manager it appears:
ALCATEL HS_USB Diagnostics 9006 /COM11/!!!!!
Not a question mark...but see Alcatel!
Otherwise DLOAD button inactive in the program for me!!
Old 12-10-2013, 22:06   #4 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Or not looking good for the failure?
Would have no driver problems?
Why not active these three buttons?
REad Partitions
Write Partitions
Restore Dload
Old 12-11-2013, 14:55   #5 (permalink)
UU2
Member: 21987
Thanks Meter: 27
It's the same problem:
"after flash my lumia 710 with mcu file RM803_OSBL_QUALCOMM.esco
flash succeess
but now can't found phone as Qualcomm MMC Storage USB Device
i device manager i found alcatel hs-usb diagnostics9006
any driver to install or i miss some step"
What is the miserable DRIVER THAT THIS CAUSES A PROBLEM?????
Windows will automatically install the drivers, but one wrong....Nokia Connectivity Cable driver or other???
Or the driver version is not good???
Old 12-11-2013, 15:19   #6 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Not the Sigma box driver for this???
He would face?
When "Qualcomm mode" tuck-away USB...is shown as a question mark:Qualcomm CDMA TECHOLOGIES MSM...will automatically switch to the Alcatel hs-usb driver!!!
This is toxin,not cyanide!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-11-2013, 16:06   #7 (permalink)
UU2
Member: 21987
Thanks Meter: 27
We have the solution!!!
Important Note to everyone!!!
Any Alcatel QC driver messes all Samsung, Nokia, LG QC driver!!!
Old 12-11-2013, 16:12   #8 (permalink)
Member: 643472
Sonork: 100.96901
Hi, it is your drivers problem, try on other PC, it will work.
Old 12-12-2013, 21:06   #9 (permalink)
UU2
Member: 21987
Thanks Meter: 27
If anyone knows how can I extract this driver from the XP, do not spare me!
There is no longer a program on my computer in which it is possible...Sigma box,Nck dongle,Alcatel Android manager....and this driver is still there!
Two computer guru working on the problem for two and a half hours and no result....i congratulate Microsoft!!!
Old 12-13-2013, 10:42   #10 (permalink)
Member: 643472
Sonork: 100.96901
Hi, write me private message with teamview details of PC which have osbl driver problem.
Old 12-13-2013, 13:29   #11 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Thus, we were able to solve:
http://forum.gsmhosting.com/vbb/f609...-open-1751251/
If anyone knows 100% that it be removed from the driver, do not hold himself!
Old 04-16-2014, 19:26   #12 (permalink)
pitbulli's Avatar
Member: 1475192
Thanks Meter: 121
1. Open Device Manager - Windows end right click on Alcatel HS-USB Diagnostics 9006 on menu.
2. select "update driver software in window."
3. select "browser my computer driver software end choose browser my computer driver software."
4. then select "let me pick from a list of device drivers on my computer."
5. In new window choose "usb composite device end install"
6. Warning Warning Warning window will appear with " you need to format the disk in drive : before you can use it. " It is important to press Cancel
7. Now in menu ATF select tab eMMC Direct end SP UNLOCK
Page generated in 0.17963 seconds with 8 queries
