02-07-2013, 09:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | lumia 710 unlock problem <<< SOLVED >>> Windows Phone Flashing Started OSBL File Found: RM803_OSBL_QUALCOMM.esco WARNING: MODEM AMSS File is not Loaded WARNING: MODEM ADSP File is not Loaded WARNING: WPOS File is not Loaded ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ================================================ Basic Phone Information ================================================ SW Version : 1600.3007.7740.11465 IMEI Plain : 359774041164945 HW Version : 112.1402.2.1 Phone Type : RM-809 Product Code : 059L3R0 Basic Product Code: 059L3Q8 Module Code : 0205040 PSN Number : MQO584753 NCSD Version : 1.5 Variant Information: VAR T-MOBILE WHITE ================================================ Extended Phone Information ================================================ Public ID : 2B5D9082F15E245C24450DD16F4C633C Wireless Lan ID: A0:F4:19:28:4C:13:00:00 Bluetooth ID : A0:F4:19:27:AFF:00:00:00:00:00:00 Rebooting to OSBL MODE ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== volume+ press ok but cant restart my set on osbl mode .pls help me urgently |
02-07-2013, 18:06 | #4 (permalink) |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | i dont know why i get late support from atf team .my every issue hang on 2-3 days .then solved .bad luck for me |
02-07-2013, 20:22 | #6 (permalink) | |
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | Quote:
yes at first time i am flashed with osbl file but wrongly i am selcet tp service ,select model and press sp unlock .when i see i am in wrong then i press emcc option scan partion and then just showing me how i put qualcome mode and osbl mode.after that i am going again flash with osbl file but cant restart my set on osbl mode.this is my problem.before i unlock same model 4-5 ps without any problem by usb with atf i am also try with dead mode also with other box (best) but same problem | |
02-08-2013, 19:36 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Now from eMMC Direct tab, click on Restore button in order to restore boot-loader DLOAD... After boot-loader is changed, you can easy flash the phone over USB by ATF ! BR | |
02-09-2013, 05:38 | #8 (permalink) | |
mobile unlocked done .thanks | |
