02-08-2014, 11:57 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Lumia 720 dead, Flash, TP or Jtag for repair? how can repair this nokia, Flash i think no becouse phone whith Volume up and power not vibrate and nothingh... Can test whith Test Point, (is more easy of Jtag),?, new vers. 11.1 ceck in automatic all need to write: M.B.R. itc.. when i select Windows 8 and 720 model , is right write all cecked parts?, after this procedure i've always need flash device right?..... If think i cannot repair whith TP, i've downloaded the BIG BOOT afp File for use Jtag, but if not is obbligatory and can repair only whith TP and Flash after, i use this way, have just soldered the wires for TP... Wait a answere for choise how repair whith Best ATF... Br allumts |
02-08-2014, 13:08 | #3 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
How can ceck the RM? i've seen that all 720 have RM-885, isn't wrote in any part, thankx for this help br | |
02-08-2014, 13:21 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @allumts 1. Connect JTAG wires to your 720, make sure USB Flex Cable is connected properly. 2. Download this LUMIA_WP8_BOOT_CHECK - Download - 4shared 3. Use file in Step 2 with ATF JTAG... It will read info of phone and tell you exactly what it is... Download the correct BIG BOOT File for it. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-10-2014, 16:07 | #5 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, i've connected all wires and cheched 10 times for JTAG, but always "No Devices found in Chain", only change i've done in Jtag is n°7 BROWN, (for solder more easy cables have removed the plate and welded BROWN on point of this), but i think it's the ground and is the same.... Quote:
Regards allumts | |
02-11-2014, 11:46 | #7 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @allumts: Software log says, you did not do anything, just selected WP8 BOOT CHECK file. You need to click on Read Info button after selecting the file and than connect phone on USB cable. BR |
02-11-2014, 12:42 | #8 (permalink) | |
yes of course, isn't the first one that i repair or unlock via Jtag or TP, but at this point is possible that Usb Connector is Broked?, not have any answered from this side, i've re-assembled phone after charged Full the Battery whith external charger and if connect usb cable not have any signal... Jtag is been cecked more times, have need of change this connector first or problem can be other?, regards allumts | |
07-30-2014, 20:06 | #9 (permalink) |
Insane Poster Join Date: Dec 2008 Location: México
Member: 922779 Status: Offline Thanks Meter: 7 | Hi, anybody can help me? Log: Loading AFP (Please Wait)...OK AFP revision 4, compiled 31/12/2013 12:22:00 p.m. ================================================== ======== Phone Type : Nokia WP8 CPU Type : Qualcomm MSM8960 / MSM8930 / MSM8227 Storage TYpe: eMMC ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Use RESET JTAG button to check the JTAG Connection 6. Click READ INFO button to Start Reading Phone Info ---------------------------------------------------------- Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! We re-checked wires solder on PCB, always same error with Lumia 925 dead phone. We just cant do it JTAG. Regards. |
08-01-2014, 07:42 | #15 (permalink) | |
When you Jtag Fail, ceck carefully in section Why Fail, reasos can be different. | |
