12-03-2012, 10:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: MOSTAGANEM Age: 41
Member: 232928 Status: Offline Thanks Meter: 124 | lumia 800 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 02BAF28A Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:04:39 |
12-03-2012, 11:13 | #3 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Poland
Member: 595848 Status: Offline Sonork: 1577176 Thanks Meter: 17 | Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Storage Device Information Manufacturer ID: 11 Application ID : 0100 Product Name : 016G4B Product Rev : 00 Product SN : 0710474F Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... ERROR: Dump Aborted, Too Much Read Failures! Total Elapsed Time 00:03:04 |
The Following User Says Thank You to SonyBB5 For This Useful Post: |
12-03-2012, 11:53 | #4 (permalink) |
Member: 595848 Status: Offline Sonork: 1577176 Thanks Meter: 17 | after reflash Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... ERROR: Dump Aborted, Too Much Read Failures! Total Elapsed Time 00:24:32 stopped at all time 52% |
12-04-2012, 03:07 | #8 (permalink) |
No Life Poster Join Date: May 2007 Location: india punjab
Member: 507832 Status: Offline Thanks Meter: 78 | br phone flash with or pru code canocat test point chak tp conthon ok then click sp unlock |
The Following User Says Thank You to thethi For This Useful Post: |
12-04-2012, 10:51 | #11 (permalink) |
Member: 595848 Status: Offline Sonork: 1577176 Thanks Meter: 17 | Angel iv tryed at last 24h maybe 15-20times , phone was in the same position at all time finally now was the last click Dumping AMSS FAT16 Region Please wait for 10-20 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:39:07 |
