02-17-2014, 06:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ropar
Member: 358277 Status: Offline Thanks Meter: 476 | lumia 800 boot repair error in 11.01 ver |
02-17-2014, 06:59 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @jai2008 It tells you to check GREEN wire? Then check Green wire... It is not a bug on ATF software... Follow instructions correctly. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-18-2014, 09:38 | #3 (permalink) |
Member: 358277 Status: Offline Thanks Meter: 476 | hi hi atf team. i repair boot ok .i dont know who's fault is it but one time boot repaired ok . but now it is only vibrating . & detecting as human interface device. but does not detecting for flashing . plz help me customer is shouting for his dead set. |
02-18-2014, 12:10 | #4 (permalink) |
Member: 358277 Status: Offline Thanks Meter: 476 | hi i have sent my phone to care for flashing but they refused that its partition r corrupted these phones cant repair . plz help atf team how can i recover my handset . |
02-20-2014, 08:39 | #6 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Karnataka , India
Member: 903576 Status: Offline Sonork: 100.1648991 Thanks Meter: 23 | nokia lumia 800 problem with boot repair 12:51:32 : ================================================== ==== 12:51:32 : eMMC Test Point Connection Module 12:51:32 : ================================================== ==== 12:51:32 : ================================================== ==== 12:51:32 : 12:51:32 : 1. DO NOT USE THE PHONE"S BATTERY 12:51:32 : 2. Connect the Soldered TP Connections to ATF Box 12:51:32 : 3. Disconnect the USB Cable and Wait until the 12:51:32 : the ATF Software will tell you to Connect the USB. 12:51:32 : 12:51:32 : 12:51:32 : Interface Reset OK! 12:51:32 : eMMC Supported Voltage Range: 12:51:32 : 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V 12:51:32 : 12:51:32 : CID : 0600003136FFFFFFFFFF195C4939 12:51:32 : CSD : 904F012A0F5903FFF6DBFFFF8A4000F9 12:51:32 : 12:51:32 : eMMC Boot Information 12:51:32 : BOOT PARTITION : USER AREA 12:51:32 : PARTITION ACCESS : R/W USER PARTITION 12:51:32 : PERM_BOOT_CFG_PROT: DISABLED 12:51:32 : PWR_BOOT_CFG_PROT : DISABLED 12:51:32 : eMMC FirmW UPDATE : DISABLED 12:51:32 : 12:51:34 : ERROR: EMMC_READ_SINGLE_BLOCK FAILED (CMD17) 12:51:34 : Check GREEN Test Point Connection 12:51:34 : 12:51:34 : BOOT Images Written Successfully! 12:51:34 : 12:51:34 : Total Elapsed Time 00:00:01 what is this i have tried 10 times but same problem |
02-24-2014, 07:03 | #7 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | same problem here on 11.01 Quote:
