07-18-2013, 16:45 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: United Kingdom
Member: 1574069 Status: Offline Thanks Meter: 32 | Lumia 800 BYTES_MISSING ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! BYTES_MISSING ERROR: Connection Refused 0x06 Check your Test Point Soldering! __________________________________________________ ______________ Here's what happened. By mistake the USB was plugged in while battery was in on the unlocking process. Only realised later. Phone got unlocked but is unable to power on. Above is the log when I'm trying to repair the boot. I am also using the GPG test point cable so no problem with the connection. What steps should I take? Please advise Regards |
