Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-12-2013, 05:49   #1 (permalink)
Member: 488365
Thanks Meter: 12
lumia 800 can not detect
cant detect lumia 800 using gpg tp cable,
when i connect just the usb to pcb phone vibrates
when i connect usb with tp cable attached to the pcb and the box , nothing happens, i get this error.
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
ERROR: Phone WAS NOT Detected!
Check the BLUE WIRE Connection
Check the GREEN WIRE Connection
Old 09-12-2013, 11:01   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hi,
What's the problem in phone? If just want to unlock it, then no need TP.
If boot is dead, then I suggest to use TP wires instead the cable. It works
with TP wires perfectly!
Page generated in 0.10222 seconds with 8 queries
