11-05-2012, 16:02 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | Lumia 800 can't unlock ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! ERROR: Connection Refused 0x06 Check your Test Point Soldering! Total Elapsed Time 00:00:09 where is problem test point good help me pls |
11-05-2012, 16:19 | #2 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Pakistan Age: 36
Member: 748029 Status: Offline Sonork: 100.1603742 Thanks Meter: 1,822 | Quote:
B,R. | |
11-05-2012, 16:38 | #3 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Solder properly in TP with short length jumper wire Br - srinibas | |
11-08-2012, 09:33 | #6 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 41
Member: 170313 Status: Offline Thanks Meter: 46 | Quote:
