11-05-2012, 13:59 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2008 Location: at work
Member: 770863 Status: Offline Sonork: 100.1597188 Thanks Meter: 123 | Lumia 800 Dead after unlock and Repair error 11:39:21 : 1. DO NOT USE THE PHONE"S BATTERY 11:39:21 : 2. Connect the Soldered TP Connections to ATF Box 11:39:21 : 3. Disconnect the USB Cable and Wait until the 11:39:21 : the ATF Software will tell you to Connect the USB. 11:39:21 : 11:39:24 : 11:39:24 : Interface Reset OK! 11:39:24 : Reading Platform Information... 11:39:24 : Selecting Active Handle... 11:39:24 : Select Handle OK! 11:39:24 : Sending Ping... 11:39:24 : Ping Reply OK! 11:39:24 : 11:39:24 : 11:39:24 : Storage Device Information 11:39:24 : Manufacturer ID: 11 11:39:24 : Application ID : 0100 11:39:24 : Product Name : 016G4B 11:39:24 : Product Rev : 00 11:39:24 : Product SN : 1A51ACD1 11:39:24 : 11:39:24 : Protection Information 11:39:24 : Write Protect A: OFF 11:39:24 : Write Protect B: OFF 11:39:24 : 11:39:24 : Writing MBR... 11:39:25 : ERROR: Block Write Failed at 0x00000000 11:39:25 : Check your Test Point Soldering! 11:39:25 : ERROR: WRITE FAILED! 11:39:25 : 11:39:25 : Total Elapsed Time 00:00:03 11:39:43 : ================================================== ==== unlocking log is still ok.... 12:07:49 : 1. DO NOT USE THE PHONE"S BATTERY 12:07:49 : 2. Connect the Soldered TP Connections to ATF Box 12:07:49 : 3. Disconnect the USB Cable and Wait until the 12:07:49 : the ATF Software will tell you to Connect the USB. 12:07:49 : 12:07:51 : 12:07:51 : Interface Reset OK! 12:07:51 : Reading Platform Information... 12:07:51 : Selecting Active Handle... 12:07:51 : Select Handle OK! 12:07:51 : Sending Ping... 12:07:51 : Ping Reply OK! 12:07:51 : 12:07:52 : 12:07:52 : Storage Device Information 12:07:52 : Manufacturer ID: 11 12:07:52 : Application ID : 0100 12:07:52 : Product Name : 016G4B 12:07:52 : Product Rev : 00 12:07:52 : Product SN : 1A51ACD1 12:07:52 : 12:07:52 : Protection Information 12:07:52 : Write Protect A: OFF 12:07:52 : Write Protect B: OFF 12:07:52 : 12:07:52 : 12:07:52 : Dumping AMSS FAT16 Region 12:07:52 : Please wait for 10-20 Minutes... 12:28:50 : 12:28:50 : WARNING: Patch Bit NOT FOUND! 12:28:50 : Maybe Phone is already UNLOCKED! 12:28:50 : 12:28:50 : Total Elapsed Time 00:21:07 Wires are too short and Its toshiba chip offcourse. |
11-05-2012, 14:52 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | 1 - Boot not repair Quote:
Br - srinibas | |
11-05-2012, 17:55 | #5 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Harare, Zimbabwe/ South Africa Age: 44
Member: 46546 Status: Offline Sonork: 100.1577435 Thanks Meter: 85 | Quote:
12-10-2012, 12:50 | #6 (permalink) |
Freak Poster Join Date: Aug 2004 Location: romania Age: 44
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | same problem here i have one dead lumia 800 after trying to unlock with tp. this is not my first lumia. i've done few but this is toshiba chip inside and after testing connection and get error phone is dead and not doing anything. testpoint is ok. i've checket many times. please any solution to revive , bcause boot repair also came with same connection error. maybe another testpoint for this toshiba chip????? |
12-10-2012, 13:04 | #7 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | one more question maybe resistors are damaged. phone came to me from another shop that tried to unlock it with no succes but phone was alive. can you tell me what values do those 2 resistor have??? i'll try to replace them and give another shot but what values do i have to search for. ATF PLEASE HELP!! CUSTOMER IS ALL OVER ME!!! |
12-10-2012, 15:10 | #11 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | answer the two resistors i am talking about are the ones with soldered tp wires on. so 10k ohm is the value. ok. the box i don't think it faulty. i've allready told you is not first lumia 800 unlocked with testpoint and this box. and box is working fine on flashing and other operations!!! |
01-07-2013, 12:03 | #12 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | atf please help as i told you, i have one lumia 800 dead. i notice a thing, when i conect tp and test connection, but only with yellow cable not together with the red one, as i connect the usb cable, phone vibrates and is detected by pc and after few seconds in device manager is detected as Nokia usb device..... also, if i connect the battery, mainboard is heating, not too much, but is heating. any ideea??? i belive something get burned wile atempting tp unlock!!! please ATF team, help me!!! |
