07-01-2013, 14:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | lumia 800 dead boot not sucsess plz help where is problem . thanxx in advance logs : - Uploaded with ImageShack.us |
07-01-2013, 15:04 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | problem in ur wires, u are not solder wire correctly check cable connectivity http://forum.gsmhosting.com/vbb/f609...epair-1680378/ |
07-01-2013, 15:15 | #3 (permalink) | |
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | Quote:
07-01-2013, 16:09 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Use Nokia FBUS cable as TP cable not use PC Lan cable Br - srinibas | |
07-01-2013, 16:34 | #7 (permalink) |
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | ok again show some tips if u 100% sure ur wire are all ok remove battery from phone put the rj45 in atf select the phone with correct rm press test connection then insert usb cable post result regards |
07-02-2013, 18:49 | #11 (permalink) |
Freak Poster Join Date: Sep 2005 Location: SPB Age: 45
Member: 182653 Status: Offline Thanks Meter: 115 | I have the same problem with Lumia 800 (the same log). The phone has been connected via cable (working and tested on lumia 710 & lumia 900) and via adapter by GPG - nothing has changed. May be hardware is faulty? |
