11-07-2012, 10:26 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Lumia 800 error during unlock here is my log please help me TEST CONNECTION 18:46:22 : 1. DO NOT USE THE PHONE"S BATTERY 18:46:22 : 2. Connect the Soldered TP Connections to ATF Box 18:46:22 : 3. Disconnect the USB Cable and Wait until the 18:46:22 : the ATF Software will tell you to Connect the USB. 18:46:22 : 18:46:27 : 18:46:27 : Interface Reset OK! 18:46:27 : Reading Platform Information... 18:46:27 : Selecting Active Handle... 18:46:27 : Select Handle OK! 18:46:27 : Sending Ping... 18:46:27 : Ping Reply OK! 18:46:27 : 18:46:27 : Lumia 800/800C Detected 18:46:27 : 18:46:27 : Storage Device Information 18:46:27 : Manufacturer ID: 90 18:46:27 : Application ID : 014A 18:46:27 : Product Name : HYNIX 18:46:27 : Product Rev : 5C 18:46:27 : Product SN : 0017AB67 18:46:27 : 18:46:27 : Protection Information 18:46:27 : Write Protect A: OFF 18:46:27 : Write Protect B: OFF SP UNLOCK 18:49:27 : ================================================== ==== 18:49:27 : ================================================== ==== 18:49:27 : Lumia Test Point Connection Module 18:49:27 : ================================================== ==== 18:49:27 : ================================================== ==== 18:49:27 : 18:49:27 : 1. DO NOT USE THE PHONE"S BATTERY 18:49:27 : 2. Connect the Soldered TP Connections to ATF Box 18:49:27 : 3. Disconnect the USB Cable and Wait until the 18:49:27 : the ATF Software will tell you to Connect the USB. 18:49:27 : 18:49:29 : 18:49:29 : Interface Reset OK! 18:49:29 : Reading Platform Information... 18:49:29 : Selecting Active Handle... 18:49:29 : Select Handle OK! 18:49:29 : Sending Ping... 18:49:29 : Ping Reply OK! 18:49:29 : 18:49:29 : Lumia 800/800C Detected 18:49:29 : 18:49:29 : Storage Device Information 18:49:29 : Manufacturer ID: 80 18:49:29 : Application ID : 0000 18:49:29 : Product Name : 18:49:29 : Product Rev : 0C 18:49:29 : Product SN : 00038123 18:49:29 : 18:49:29 : Protection Information 18:49:29 : Write Protect A: OFF 18:49:29 : Write Protect B: OFF 18:49:29 : 18:49:29 : 18:49:29 : Dumping AMSS FAT16 Region 18:49:29 : Please wait for 2-4 Minutes... 18:53:59 : Patch Bit Found... 18:53:59 : Total Patch Bits Found: 1 18:53:59 : Patching AMSS... 18:53:59 : ERROR: Connection Refused 0x0C 18:53:59 : Check your Test Point Soldering! 18:53:59 : 18:53:59 : Total Elapsed Time 00:04:39 Now It shows like this please help me 19:06:42 : ================================================== ==== 19:06:42 : ================================================== ==== 19:06:42 : Lumia Test Point Connection Module 19:06:42 : ================================================== ==== 19:06:42 : ================================================== ==== 19:06:42 : 19:06:42 : 1. DO NOT USE THE PHONE"S BATTERY 19:06:42 : 2. Connect the Soldered TP Connections to ATF Box 19:06:42 : 3. Disconnect the USB Cable and Wait until the 19:06:42 : the ATF Software will tell you to Connect the USB. 19:06:42 : 19:06:50 : 19:06:50 : Interface Reset OK! 19:06:50 : Reading Platform Information... 19:06:50 : Selecting Active Handle... 19:06:50 : Select Handle OK! 19:06:50 : Sending Ping... 19:06:50 : Ping Reply OK! 19:06:50 : 19:06:52 : ERROR: Connection Refused 0x06 19:06:52 : Check your Test Point Soldering! While i check my soldering and try other methods too like removing yellow wire but same please help me |
11-07-2012, 12:42 | #3 (permalink) | |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Quote:
after unlock error now its continusely giving same error ERROR: Connection Refused 0x06 did everything change wires, change pc, change box and also try with ATF lite but same result ... its not my 1st time i unlock lumia | |
11-07-2012, 13:34 | #4 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Which box do you have ? | |
11-08-2012, 08:58 | #6 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Brother see my log plz ...1st i check connection, at same test points i unlock and on same test points its giving error and after this its continuously giving error while i change test point cable, PC, and box but result same ERROR: Connection Refused 0x06 |
11-08-2012, 09:13 | #7 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | Quote:
its just connection problem here is all is okay http://forum.gsmhosting.com/vbb/8913260-post149.html check pinouts again , check cables wires be sure you are doing everything according to the pinouts given by team | |
11-08-2012, 09:23 | #8 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 41
Member: 170313 Status: Offline Thanks Meter: 46 | Quote:
chip no support only hynix is good ulock | |
11-08-2012, 10:15 | #10 (permalink) | ||
Brother as i said i check with every method i unlock 3 phones on my 1st test point connection and its 2nd phone get error before this it was Toshiba chip but now its hynix chip that i unlocked before 3 times. but as i said i tried more than 15 times with every possible method method, change pc, change test point cable and box too will check again check here http://forum.gsmhosting.com/vbb/8762706-post42.html give me ur conork id please | ||
11-08-2012, 14:48 | #11 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | I want to say that after unlocking error ATF continuously gives error even test points are ok too . if we can make correct test points on 1st attempt than why we can't make it after 10 or 20 times ... think please ..... Please take a look on these posts too please http://forum.gsmhosting.com/vbb/8778080-post1.html http://forum.gsmhosting.com/vbb/8756979-post1.html http://forum.gsmhosting.com/vbb/8778155-post1.html http://forum.gsmhosting.com/vbb/8795070-post1.html http://forum.gsmhosting.com/vbb/8768283-post1.html |
12-15-2012, 19:28 | #12 (permalink) |
Freak Poster Join Date: Aug 2004 Location: romania Age: 44
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | same problem here I have the same error . I have one lumia 800 that came to me for unlock. Phone was powering and no problem. After trying to unlock with tp the same eror came to me too. The problem is that after that phone is not powering anymore. Is dead and every time i 've tried to repair boot i receive the same error. Please. Any solution to fix that? I thought at one point that testpoint was damaged but is not that. Please , if anyone have any solution post it here!! |
01-05-2013, 15:01 | #13 (permalink) |
Member: 76643 Status: Offline Sonork: 100.1606758 Thanks Meter: 21 | lumia 800 still dead i have one mainboard that was killed by ATF big box in very similar way. i bought new box, ATF lightning and toshiba chips work now. so i belive big box was the problem. if i trie to conect now a lumia, toshiba chip, with big box give error but with same atf software and lightning box all is ok. problem is that mainboard killed by big box is npt conecting anymore even with lightning box. all the time i try is giving this error: ERROR: Connection Refused 0x0C Check your Test Point Soldering! testpoint seems ok, box is the new one and is working. what can be done to revive this lumia?? |
