06-30-2013, 18:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | lumia 800 flash error - [SOLVED, SOLUTION INSIDE] OSBL File Found: RM801_12w22_prod_generic_nokia_osbl.esco AMSS File Found: RM801_12w22_prod_generic_amss.esco ADSP File Found: RM801_12w22_prod_generic_adsp.esco WPOS File Found: RM801_12220_prod_490_01_boot.esco USER AREA ERASE File Found: RM801_12w22_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
07-03-2013, 16:31 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
07-08-2013, 18:17 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Location: romania Age: 48
Member: 48215 Status: Offline Thanks Meter: 19 | I have the same problem.....afther try to unlock nokia lumia 800 i kill the phone....i try to repair boot...all the steps was done....at the end when i try to power up the phone only nokia on screen...if i try to flas i receive the mesage: Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED When i try to flash the phone i press vol plus and power and insert the usb cable I repeated this operation (repair boot ) 3 times...no error every time. any solution? |
07-09-2013, 06:26 | #9 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Do as mention there , 100% you will get result Br - srinibas | |
07-09-2013, 19:01 | #12 (permalink) | |
Member: 1263622 Status: Offline Thanks Meter: 149 | Quote:
SIR,My problem Not solved.......................same problem now i have 2 set. Need other way.........i think its hardware...im right ??? | |
