09-22-2012, 13:41 | #1 (permalink) |
Freak Poster Join Date: May 2001
Member: 4527 Status: Offline Thanks Meter: 40 | Lumia 800 flashing problem on 2 PCs "Switching to NOKIA MODE Polling Ports... (Please Wait)" On the bottom again switching message between "Initializing Phone" and "Windows Mobile Found (Nokia Mode)". In device manager again see "Nokia USB connectivity". It stucks there forever. If I try flashing like dead phone and connect to usb with volume+ pressed then phone vibrates but ATF still stays on "scanning". Few seconds later phone restarts, ATF "scanning" reaches 100% and give message: "ERROR: Active Phone Handle was NOT DETECTED" I never see DLOAD or Qualcomm device in device manager. Tried on 2 differents PCs both running XP. Same problem with 3 Lumia already. All of them I could flash using cyclone in dead mode. Seems could be problem with OSBL drivers but how to install them correctly? Here is log when flashing like alive phone: Code: Windows Phone Flashing Started OSBL File Found: RM801_12w22_prod_generic_nokia_osbl.esco AMSS File Found: RM801_12w22_prod_generic_amss.esco ADSP File Found: RM801_12w22_prod_generic_adsp.esco WPOS File Found: RM801_12220_prod_418_05_boot.esco USER AREA ERASE File Found: RM801_12w22_prod_generic_user_area_erase.esco ====================================================== Windows Phone Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ====================================================== Switching to NOKIA MODE Polling Ports... (Please Wait) ================================================ Basic Phone Information ================================================ SW Version : 1600.2487.8107.12070 IMEI Plain : 352826051xxxxxx HW Version : 112.1402.2.4 Product Code : 059L7C6 Basic Product Code: 059J2N6 Module Code : 0205051 PSN Number : 00B6D78AB NCSD Version : 1.9 ================================================ Extended Phone Information ================================================ Public ID : FB364D9CA0F304B3A3BFC0E568D63096 Wireless Lan ID: 3C:36:3D:C5:C4:76:00:00 Bluetooth ID : 3C:36:3D:C7:0C:6B:00:00:00:00:00:00 Rebooting to OSBL MODE Switching to NOKIA MODE Polling Ports... (Please Wait) thanks in advance. Regards. |
09-22-2012, 22:51 | #2 (permalink) |
Member: 4527 Status: Offline Thanks Meter: 40 | Maybe at least someone with XP could tell me if this is normal that connecting Lumia using vol+ I see "Nokia USB connectivity" device? Which driver should be used when connecting with vol+ mode? Nokia connectivity driver or some other? |
