03-14-2014, 11:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | lumia 800 imei failed after unlock repair Status : WRITE OSBL CERTIFICATE FAILED 2)lumia show this so i try this http://forum.gsmhosting.com/vbb/f609...epair-1673102/ 3)After dead phone repair and phone unlock FOUND: Qualcomm MMC Storage USB Device Mounted Drive Number: 2 MBR Entry[0]: Flags : 128 Type : 0x4D - DBL Starting Sector: 0x00000001 Sector Count : 0x000003E8 MBR Entry[1]: Flags : 0 Type : 0x46 - OSBL Starting Sector: 0x000003E9 Sector Count : 0x00000BB8 MBR Entry[2]: Flags : 0 Type : 0x0C - AMSS_ADSP Starting Sector: 0x00000FA1 Sector Count : 0x000493E0 EBR Entry[0]: Flags : 0 Type : 0xEF - PMM Starting Sector: 0x0004A386 Sector Count : 0x00000080 EBR Entry[1]: Flags : 0 Type : 0x58 - ENC_STORAGE_A Starting Sector: 0x0004A406 Sector Count : 0x00001800 EBR Entry[2]: Flags : 0 Type : 0x4A - ENC_STORAGE_B Starting Sector: 0x00060000 Sector Count : 0x00001800 EBR Entry[3]: Flags : 0 Type : 0x4B - ENC_STORAGE_C Starting Sector: 0x00061800 Sector Count : 0x00001800 EBR Entry[4]: Flags : 0 Type : 0x48 - WP_OS Starting Sector: 0x00080000 Sector Count : 0x01D38FFF Dumping AMSS FAT16 Region Please wait for 15-20 Seconds... Patch Bit Found... Patch Bit Found... Total Patch Bits Found: 2 Patching AMSS... SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:00:17 Loading Partition File: C:\Program Files\Common Files\Nokia\DataPackage\Products\rm-801\RM801_12220_prod_227_10_boot.esco Writing Partition 0x48 Partition 0x48 Write OK Total Elapsed Time 00:01:48 NOW PHONE AIRPLANE MODE NOT OFF AND WIFI ON NOT OFF EVEN PHONE RESET !! |
03-14-2014, 11:48 | #3 (permalink) |
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Windows Phone Flashing Started OSBL File Found: RM801_12w22_prod_generic_nokia_osbl.esco AMSS File Found: RM801_12w22_prod_generic_amss.esco ADSP File Found: RM801_12w22_prod_generic_adsp.esco USER AREA ERASE File Found: RM801_12w22_prod_generic_user_area_erase.esco WARNING: WPOS File is not Loaded ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Switching to NOKIA MODE [NCSD] Polling Ports... (Please Wait) ================================================ Basic Phone Information ================================================ SW Version : 1750.0805.8773.12220 HW Version : 112.1402.2.3 Phone Type : RM-801 Product Code : 059L7H0 Basic Product Code: 059J2N6 Module Code : 0205051 PSN Number : 0064B3DAB NCSD Version : 1.9 Variant Information: T-Mobile UK GB Matt Black V3 GV ================================================ Extended Phone Information ================================================ Public ID : 932A325EA2B643746F8DB1F384D9571F Wireless Lan ID: 94:3A:F0:67:4A:9E:00:00 Bluetooth ID : 94:3A:F0:67:23:68:00:00:00:00:00:00 Rebooting to OSBL MODE Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
03-14-2014, 12:10 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @AhsanNawaz You cannot flash this phone anymore with NokiaCareSuite or with ATF Normal WP7 flashing method. You can flash this phone via eMMC Direct only same as you did before and about IMEI damaged - it can't be repaired as I said in my previous post. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
03-14-2014, 15:57 | #6 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | Quote:
how to flash? | |
03-14-2014, 16:30 | #7 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
03-16-2014, 12:52 | #8 (permalink) |
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | |
