10-28-2013, 14:14 | #1 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 345808 Status: Offline Thanks Meter: 21 | lumia 800 with out connect its running ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. MMC_TP_SEND_CMD: 0200000000A9FF MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 REPLY CMD1: 185E5E5E5E5E5E MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! Try to Adjust VCCIO Voltage CMD1 Reply: 0x5E5E5E5E |
10-28-2013, 14:59 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Follow the instruction... 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. MMC_TP_SEND_CMD: 8202FF010191 MMC_TP_SEND_CMD: 8202FF010191 ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! Try to Adjust VCCIO Voltage CMD1 Reply: 0x5E5E5E5E |
