03-31-2013, 16:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Lumia 800 rm-401 successfull unlocked via tp method with easy steps 1- make test points mentioned in sticky thread here is success log: Code: 18:54:48 : ====================================================== 18:54:48 : ====================================================== 18:54:48 : Lumia Test Point Connection Module 18:54:48 : ====================================================== 18:54:48 : ====================================================== 18:54:48 : 18:54:48 : 1. DO NOT USE THE PHONE"S BATTERY 18:54:48 : 2. Connect the Soldered TP Connections to ATF Box 18:54:48 : 3. Disconnect the USB Cable and Wait until the 18:54:48 : the ATF Software will tell you to Connect the USB. 18:54:48 : 18:54:50 : 18:54:50 : Interface Reset OK! 18:54:50 : Reading Platform Information... 18:54:50 : Selecting Active Handle... 18:54:50 : Select Handle OK! 18:54:50 : Sending Ping... 18:54:50 : Ping Reply OK! 18:54:50 : 18:54:50 : Lumia 800/800C Detected 18:54:50 : 18:54:50 : Storage Device Information 18:54:50 : Manufacturer ID: 90 18:54:50 : Application ID : 014A 18:54:50 : Product Name : HYNIX 18:54:50 : Product Rev : 5C 18:54:50 : Product SN : 0AE28520 18:54:50 : 18:54:50 : Protection Information 18:54:50 : Write Protect A: OFF 18:54:50 : Write Protect B: OFF 18:54:50 : 18:54:50 : 18:54:50 : Dumping AMSS FAT16 Region 18:54:50 : Please wait for 2-4 Minutes... 18:59:09 : Patch Bit Found... 18:59:09 : Total Patch Bits Found: 1 18:59:10 : Patching AMSS... 18:59:10 : Patch OK! 18:59:10 : 18:59:10 : SP Unlock Done! 18:59:10 : 18:59:10 : PIN: 00000000 18:59:10 : PUK: 0000000000 18:59:10 : 18:59:10 : Total Elapsed Time 00:04:22 some time phone shows no service after unlock then you have to reset your phone all will be ok having good signal. MianLinks |
