08-07-2014, 14:50 | #1 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1285193 Status: Offline Thanks Meter: 0 | Lumia 800 stuck on orange logo |
08-07-2014, 16:10 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | welcome to the software world .. you will use ATF cuz it's the best nokia tool .. 1-download the FW with NaviFirm .. and put it in C:\Program Files\Nokia\Phoenix\Products\ .. 2-open ATF and choose Windows Phone and select phone model .. 3-check Phoenix INI and the FW will be added automaticlly .. 4-now press Flash .. 5-turn off the phone and wait 5 sec then connect it to USB and the flashing will start ..? 6-wait untill the flash is done then disconnect the phone and start it .. that's it .. hope that helped .. Regards. |
08-07-2014, 16:16 | #4 (permalink) | |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | Quote:
don't worry about phone info .. if it's detected by PC then just flash it as i explained .. wait for result ... | |
08-07-2014, 18:35 | #5 (permalink) |
Member: 1285193 Status: Offline Thanks Meter: 0 | ERROR: Data Rejected at SEQ 0x1 ERROR: Data Rejected at SEQ 0x2 Sending OSBL Certificate HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E Certificate Size: 452 Bytes ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED |
08-07-2014, 20:51 | #6 (permalink) | |
here is the solution .. http://forum.gsmhosting.com/vbb/f609...epair-1673102/ | |
08-09-2014, 12:47 | #8 (permalink) |
Member: 1285193 Status: Offline Thanks Meter: 0 | Hard reset not work for me. I've got only imageshack. com/i/p2FKWzW3j and imageshack. com/ i/eyGfLlGIj cable, can i do it with it? Last edited by chajniq; 08-09-2014 at 12:53. |
