01-07-2015, 20:29 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Portugal
Member: 239543 Status: Offline Thanks Meter: 7 | Lumia 800 test point error I use the GPG Test point and the test connection works perfect but when i tried to repair boot i have error Can anyone help? Thanks. ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48594E4958205C001A9074 CSD : D04F01320F5903FFFFFFFFFF8A400001 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 15896412160 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB Lumia 800/800C Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.12 Product SN : 001A9074 Manufactured : January 2011 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48594E4958205C001A9074_CA6E6362.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR... Write Success! Writing DBL... Block Write CRC Error Block Write CRC Error Block Write CRC Error Block Write CRC Error Block Write CRC Error Block Write CRC Error ERROR: Block Write Failed at 0x000003BC Check your Test Point Soldering! ERROR: WRITE FAILED! Total Elapsed Time 00:00:47 |
01-07-2015, 21:01 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @bezano1, you testpoint and connection works perfect? and this What's?: Quote:
BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
