10-31-2012, 15:44 | #1 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Lumia 800 unlock not work flash ic toshiba Quote:
10-31-2012, 18:03 | #2 (permalink) | |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | ATF not support 1600.xxxxxxx firmware with update phone to 1750.xxxxx unlock work ok. Quote:
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
10-31-2012, 18:57 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @wgmmmx1 Thanks for reporting. It was also posted here: http://forum.gsmhosting.com/vbb/f609...819-a-1540417/ B.R. |
10-31-2012, 21:23 | #4 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Yes but after is write that from atf v9.12 no need follow this instruction and I got other error then others I got patch block not found not all correct and after not work pin or puk code. |
11-01-2012, 20:00 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iPhone Age: 46
Member: 599385 Status: Offline Sonork: 100.1583205 Thanks Meter: 82 | Same thing here: ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 094EC280 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... WARNING: Patch Bit NOT FOUND! Maybe Phone is already UNLOCKED! Total Elapsed Time 00:04:25 |
