09-20-2012, 13:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 711273 Status: Offline Thanks Meter: 81 | lumia 800 unlock ok but code error Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : @YNIX Product Rev : 5C Product SN : 05A0703C Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Byte Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:04:52 pin & puk incorrect how to solve this problem atf team please help |
09-24-2012, 08:03 | #4 (permalink) |
Member: 711273 Status: Offline Thanks Meter: 81 | hi, atf team i Flash with this version 1750.0805.8773.12220_017 lumia 800 but not required nck or puk unlock code i think counter blocked how to enter pin & puk code SW Version : 1750.0805.8773.12220 IMEI Plain : 359*********** HW Version : 112.1402.2.3 Product Code : 059L7C6 Basic Product Code: 059J2N6 Module Code : 0205051 PSN Number : 004A7D1AB NCSD Version : 1.9 ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 05A0703C Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Byte Found... Patch Byte Found... Total Patch Bits Found: 2 Patching AMSS... Patch OK! Patch OK! please solve my problem SP Unlock Done! PIN: 00000000 PUK: 0000000000 |
