05-07-2015, 07:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: india
Member: 368923 Status: Offline Thanks Meter: 85 | lumia 800 unlock problem 20:04:17 : eMMC Test Point Connection Module 20:04:17 : ================================================== ==== 20:04:17 : ================================================== ==== 20:04:17 : 20:04:17 : 1. DO NOT USE THE PHONE"S BATTERY 20:04:17 : 2. Connect the Soldered TP Connections to ATF Box 20:04:17 : 3. Disconnect the USB Cable and Wait until the 20:04:17 : the ATF Software will tell you to Connect the USB. 20:04:17 : 20:04:17 : 20:04:17 : Interface Reset OK! 20:04:17 : eMMC Access Type: SECTOR MODE 20:04:17 : eMMC Supported Voltage Range: 20:04:17 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 20:04:17 : 20:04:17 : CID : 90014A48594E4958205C001C787CBEC3 20:04:17 : CSD : D04F01320F5903FFFFFFFFFF8A400001 20:04:17 : 20:04:17 : eMMC Boot Information 20:04:17 : Revision 1.5 (for MMC v4.41) 20:04:17 : BOOT PARTITION : USER AREA 20:04:17 : PARTITION ACCESS : R/W USER PARTITION 20:04:17 : PERM_BOOT_CFG_PROT : DISABLED 20:04:17 : PWR_BOOT_CFG_PROT : DISABLED 20:04:17 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 20:04:17 : RESET BUS WIDTH : ENABLED 20:04:17 : eMMC FirmW UPDATE : DISABLED 20:04:17 : EMMC CACHE SIZE : 0 KB 20:04:17 : SUPER PAGE SIZE : 3584 KB 20:04:17 : HC ERASE GROUP SIZE: 8192 KB 20:04:17 : USER AREA SIZE : 15896412160 BYTES 20:04:17 : BOOT PARTITION SIZE: 4096 KB 20:04:17 : RPMB PARTITION SIZE: 4096 KB 20:04:17 : 20:04:17 : Lumia 800/800C Detected 20:04:17 : 20:04:17 : eMMC Device Information 20:04:17 : Manufacturer ID: HYNIX 20:04:17 : Device Type : Embedded BGA 20:04:17 : Application ID : 4A 20:04:17 : Product Name : HYNIX 20:04:17 : Product Rev : 5.12 20:04:17 : Product SN : 001C787C 20:04:17 : Manufactured : January 2011 20:04:17 : 20:04:17 : Card Specific Data 20:04:17 : CSD_STRUCTURE : Extended 20:04:17 : SPEC_VERS : Version 4.1/4.2/4.3 20:04:17 : TAAC : 300 ns 20:04:17 : TRAN_SPEED : 4000000 KHz 20:04:17 : READ_BL_LEN : 512 Bytes 20:04:17 : C_SIZE : HIGH CAPACITY 20:04:17 : WP_GRP_ENABLE : YES 20:04:17 : WRITE_BL_LEN : 512 Bytes 20:04:17 : CONTENT_PROT_APP : NO 20:04:17 : PERM_WRITE_PROTECT: NO 20:04:17 : TMP_WRITE_PROTECT : NO 20:04:17 : 20:04:17 : Extended CSD Saved: 20:04:17 : 90014A48594E4958205C001C787CBEC3.ext_csd 20:04:17 : Backup Directory: 20:04:17 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 20:04:17 : 20:04:17 : 20:04:17 : Dumping Custom Region 20:04:17 : Please wait for some time... 20:04:17 : Partition Selected: USER AREA 20:04:17 : (eMMC Clock 15000000 Hz) 20:04:27 : ================================================== ==== 20:04:27 : ================================================== ==== 20:04:27 : eMMC Test Point Connection Module 20:04:27 : ================================================== ==== 20:04:27 : ================================================== ==== 20:04:27 : 20:04:27 : 1. DO NOT USE THE PHONE"S BATTERY 20:04:27 : 2. Connect the Soldered TP Connections to ATF Box 20:04:27 : 3. Disconnect the USB Cable and Wait until the 20:04:27 : the ATF Software will tell you to Connect the USB. 20:04:27 : 20:04:27 : 20:04:27 : Interface Reset OK! 20:04:27 : eMMC Access Type: SECTOR MODE 20:04:27 : eMMC Supported Voltage Range: 20:04:27 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 20:04:27 : 20:04:27 : CID : 90014A48594E4958205C001C787CBEC3 20:04:27 : CSD : D04F01320F5903FFFFFFFFFF8A400001 20:04:27 : 20:04:27 : eMMC Boot Information 20:04:27 : Revision 1.5 (for MMC v4.41) 20:04:27 : BOOT PARTITION : USER AREA 20:04:27 : PARTITION ACCESS : R/W USER PARTITION 20:04:27 : PERM_BOOT_CFG_PROT : DISABLED 20:04:27 : PWR_BOOT_CFG_PROT : DISABLED 20:04:27 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 20:04:27 : RESET BUS WIDTH : ENABLED 20:04:27 : eMMC FirmW UPDATE : DISABLED 20:04:27 : EMMC CACHE SIZE : 0 KB 20:04:27 : SUPER PAGE SIZE : 3584 KB 20:04:27 : HC ERASE GROUP SIZE: 8192 KB 20:04:27 : USER AREA SIZE : 15896412160 BYTES 20:04:27 : BOOT PARTITION SIZE: 4096 KB 20:04:27 : RPMB PARTITION SIZE: 4096 KB 20:04:27 : 20:04:27 : Lumia 800/800C Detected 20:04:27 : 20:04:27 : eMMC Device Information 20:04:27 : Manufacturer ID: HYNIX 20:04:27 : Device Type : Embedded BGA 20:04:27 : Application ID : 4A 20:04:27 : Product Name : HYNIX 20:04:27 : Product Rev : 5.12 20:04:27 : Product SN : 001C787C 20:04:27 : Manufactured : January 2011 20:04:27 : 20:04:27 : Card Specific Data 20:04:27 : CSD_STRUCTURE : Extended 20:04:27 : SPEC_VERS : Version 4.1/4.2/4.3 20:04:27 : TAAC : 300 ns 20:04:27 : TRAN_SPEED : 4000000 KHz 20:04:27 : READ_BL_LEN : 512 Bytes 20:04:27 : C_SIZE : HIGH CAPACITY 20:04:27 : WP_GRP_ENABLE : YES 20:04:27 : WRITE_BL_LEN : 512 Bytes 20:04:27 : CONTENT_PROT_APP : NO 20:04:27 : PERM_WRITE_PROTECT: NO 20:04:27 : TMP_WRITE_PROTECT : NO 20:04:27 : 20:04:27 : Extended CSD Saved: 20:04:27 : 90014A48594E4958205C001C787CBEC3.ext_csd 20:04:27 : Backup Directory: 20:04:27 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 20:04:27 : 20:04:27 : 20:04:27 : Dumping Custom Region 20:04:27 : Please wait for some time... 20:04:27 : Partition Selected: USER AREA 20:04:27 : (eMMC Clock 15000000 Hz) 20:04:34 : Patch Bit Found... 20:04:34 : Total Patch Bits Found: 1 20:04:34 : Patching AMSS... 20:04:35 : Patch OK! 20:04:35 : 20:04:35 : SP Unlock Done! 20:04:35 : 20:04:35 : PIN: 00000000 20:04:35 : PUK: 0000000000 20:04:35 : 20:04:35 : Total Elapsed Time 00:01:28 |
05-13-2015, 19:48 | #4 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | any one know to solve this crap problem of qualcomm mode any software want repair this mobile via USB |
05-14-2015, 06:20 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
