09-27-2012, 14:06 | #1 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 542140 Status: Offline Thanks Meter: 10 | lumia 800 unlock prock problem < select proper phone type> - [SOLUTION INSIDE] ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0A641978 Protection Information Write Protect A: OFF Write Protect B: OFF ERROR: Select Correct Phone Type! Total Elapsed Time 18:34:17 tried many many times still same plz help |
09-27-2012, 15:02 | #3 (permalink) |
Member: 542140 Status: Offline Thanks Meter: 10 | still same ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0A641978 Protection Information Write Protect A: OFF Write Protect B: OFF ERROR: Select Correct Phone Type! Total Elapsed Time 19:31:35 ERROR: Select Correct Phone Type! Total Elapsed Time 19:31:35 ERROR: Select Correct Phone Type! |
09-27-2012, 15:06 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | |
09-27-2012, 15:29 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | It is very simple,, just follow what the ATF Software tells you... ERROR: Select Correct Phone Type! Total Elapsed Time 19:31:35 ERROR: Select Correct Phone Type! Total Elapsed Time 19:31:35 ERROR: Select Correct Phone Type! Select Correct Phone Type simply means Select Correct Phone Type |
