03-27-2013, 10:50 | #1 (permalink) |
Registered User Join Date: Aug 2010
Member: 1359163 Status: Offline Thanks Meter: 37 | Lumia 800 unlocked with atf, after update zune still lock! ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0014D9D4 Protection Information Write Protect A: OFF Write Protect B: OFF and enter pin 000000000000 phone have no lock when client update Lumia via ZUNE phone have still simlock code and any PIN or PUK zero`s dont work any solution ? |
03-27-2013, 11:14 | #2 (permalink) |
Member: 1359163 Status: Offline Thanks Meter: 37 | log from atf; ================================================== ==== ================================================== ==== Lumia Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 800/800C Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5C Product SN : 0014D9D4 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Minutes... Patch Bit Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:23:18 and enter pin 0000000000 phone have no lock when client update Lumia via ZUNE phone have still simlock code any solution ? |
03-27-2013, 12:48 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | ATF do a parch unlock so after flash it will lock again . Need to unlock again Better way to flash the set after unlock is skip AMSS , then the phone will remain unlock Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
