05-27-2014, 04:42 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | lumia 820 rm-825 strange problam. flash done with latest firmware but not solved. phone hangs on this logo when try to on device. please provide me a solution thanks |
05-27-2014, 05:45 | #2 (permalink) |
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | flashing log flashing log Code: Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ====================================================== IMEI: 355XXXXXXXXXXXX Version: 1.1.1.2 Product Code: 059R028 Module Code: 0205162 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00ED0000 Block ID 0x05 : Nokia.MSM8960.P5174.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 020109011000 UEFI App: FLASH APP Flash App Protocol Version: 1.9 Flash App Implementation Version: 1.16 Query ROOT KEY HASH... ROOT_KEY_HASH: DB73418E5840941CE7BD35949085B8F74628D511F19285A092ED3B600A64CC29 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:24 |
05-27-2014, 06:32 | #3 (permalink) |
Freak Poster Join Date: Sep 2005 Location: SPB Age: 45
Member: 182653 Status: Offline Thanks Meter: 115 | Its hardware problem, why you repair boot? Solution? Change midle cover with side key flex or try to turn on without this cover and you will see a miracle |
