08-29-2014, 07:12 | #1 (permalink) |
Insane Poster Join Date: Oct 2012 Location: Technology city
Member: 1823012 Status: Offline Thanks Meter: 10 | Lumia 822 flashing problem tried many firmware but no success Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 354597050041489 Version: 1.1.1.3 Product Code: 059Q5L9 Module Code: 0205158 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00000000 Block ID 0x05 : Nokia.MSM8960.P5219.3.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020112020200 UEFI App: FLASH APP Flash App Protocol Version: 1.18 Flash App Implementation Version: 2.2 Query ROOT KEY HASH... ROOT_KEY_HASH: A0AE29AC24C843250D2DD0FFD409A649B4E4A09ED3B1A78413 FB2B94B7476AAB Sending Image Signatures... ERROR: Flash Signature Block REJECTED! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
08-29-2014, 07:17 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @johnkago You can try to bypass the flash file checking by using this ATF software: AdvanceBox - Download - 4shared - Linus Hernandez But if phone will still not accept it, then you need to rewrite boot of this phone. Show logs of flashing when using the new ATF Software from the link as well. B.R. |
08-29-2014, 09:24 | #5 (permalink) |
Member: 1823012 Status: Offline Thanks Meter: 10 | Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 354597050041489 Version: 1.1.1.3 Product Code: 059Q5L9 Module Code: 0205158 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00000000 Block ID 0x05 : Nokia.MSM8960.P5219.3.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020112020200 UEFI App: FLASH APP Flash App Protocol Version: 1.18 Flash App Implementation Version: 2.2 Query ROOT KEY HASH... ROOT_KEY_HASH: A0AE29AC24C843250D2DD0FFD409A649B4E4A09ED3B1A78413 FB2B94B7476AAB Sending Image Signatures... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) This Flash File is NOT COMPATIBLE with this Phone. Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x00420000 Check your Flash File and Phone Connection ERROR: Flashing Failed! |
08-29-2014, 10:17 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @johnkago Hi, this means you need to repair BOOT phone via eMMC TP. This is FREE and can be done by your ATF Box + a few wires... Check here: http://forum.gsmhosting.com/vbb/10399850-post2.html |
08-29-2014, 10:53 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @johnkago Download that "mmc" file for Lumia 822... Load it with ATF Software, as shown in screenshot. It will show you PINOUT... Use old FBUS cable, no need eMMC Adapter. It just need wires to connect to the eMMC TP on the phone. B.R. |
08-29-2014, 15:40 | #9 (permalink) |
Member: 1823012 Status: Offline Thanks Meter: 10 | F-bus to use to revive lumia I solder wires correctly.on lumia 822.am suspecting this rg45 fbus please tell me exactly f-bus ..its not detecting anything ....my fbus cable i used with seven colored wires...help me to knw that cable iwill revive this lumia and post results |
08-30-2014, 06:32 | #10 (permalink) |
