Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-15-2014, 17:27   #1 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
Lumia 822 retries so many tyms on writing blocks help me please
Old 09-15-2014, 17:29   #2 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
Old 09-15-2014, 17:30   #3 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
Old 09-16-2014, 05:49   #4 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@Techsky
You Screenshots are too small. I cannot see anything.
Anyway, did you use EXTERNAL power of just USB Power connected to phone?
It would give you better results if you used a pull-up resistor on GREEN and BLUE to 2.8v external power on Vcc and VccQ. Like what I put in the pinout as "optional".
I have same phone in hand now, I can show you how later.
B.R.
Old 09-16-2014, 06:08   #5 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 206
i used usb and 2resistor 100ohms ...only
Old 09-16-2014, 08:23   #6 (permalink)
Member: 651945
@Techsky
Ok, that wont work at all... Remove the 2 resistors if you are just using USB cable for POWER.
Connect only 4 wires to phone.
BROWN --- GROUND
RED --- CLK
BLUE --- CMD
GREEN --- DATA
NO NEED TO CONNECT YELLOW or PINK.
NO NEED TO CONNECT Vcc or VccQ
In eMMC Tool set the following
CPU Type: NOKIA LUMIA -SNAPDRAGON 2,3,4
VCCIO: 2.80 V
SPEED: 7.50 Mhz or 15 Mhz
1. Disconnect USB Cable from Phone
2. Click "Scan eMMC" it will tell you to connect USB Cable to Phone
3. Connect USB Cable to phone
       eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
   the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010030313647384200E38F08AF
CSD : D00E00320F5903FFFFFFFFEF9640002F
eMMC Boot Information
Revision 1.5 (for MMC v4.41)
BOOT PARTITION     : USER AREA
PARTITION ACCESS   : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT  : DISABLED
BOOT MODE          : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH    : ENABLED
eMMC FirmW UPDATE  : DISABLED
EMMC CACHE SIZE    : 0 KB
SUPER PAGE SIZE    : 3584 KB
HC ERASE GROUP SIZE: 8192 KB
USER AREA SIZE     : 15938355200 BYTES
BOOT PARTITION SIZE: 2048 KB
RPMB PARTITION SIZE: 256 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type    : Embedded BGA
Application ID : 00
Product Name   : 016G8B
Product Rev    : 0.0
Product SN     : E38F08AF
Manufactured   : January 2012
Card Specific Data
CSD_STRUCTURE     : Extended
SPEC_VERS         : Version 4.1/4.2/4.3
TAAC              : 3 ns
TRANS_SPEED       : 4000000 KHz
READ_BL_LEN       : 512 Bytes
C_SIZE            : HIGH CAPACITY
WP_GRP_ENABLE     : YES
WRITE_BL_LEN      : 512 Bytes
CONTENT_PROT_APP  : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010030313647384200E38F08AF_10E333BA.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
B.R.
Old 09-16-2014, 08:33   #7 (permalink)
Member: 651945
Hi,
Test Results Here:
Reading 512 MB @ 15Mhz in just 6 minutes
Test Phones... tested on revision 1 and revision 2 PCB. Both ok.
Test Phone PCB v1 wired up.
B.R.
Page generated in 0.18684 seconds with 9 queries
