09-16-2014, 05:49 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Techsky You Screenshots are too small. I cannot see anything. Anyway, did you use EXTERNAL power of just USB Power connected to phone? It would give you better results if you used a pull-up resistor on GREEN and BLUE to 2.8v external power on Vcc and VccQ. Like what I put in the pinout as "optional". I have same phone in hand now, I can show you how later. B.R. |
09-16-2014, 08:23 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Techsky Ok, that wont work at all... Remove the 2 resistors if you are just using USB cable for POWER. Connect only 4 wires to phone. BROWN --- GROUND RED --- CLK BLUE --- CMD GREEN --- DATA NO NEED TO CONNECT YELLOW or PINK. NO NEED TO CONNECT Vcc or VccQ In eMMC Tool set the following CPU Type: NOKIA LUMIA -SNAPDRAGON 2,3,4 VCCIO: 2.80 V SPEED: 7.50 Mhz or 15 Mhz 1. Disconnect USB Cable from Phone 2. Click "Scan eMMC" it will tell you to connect USB Cable to Phone 3. Connect USB Cable to phone Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010030313647384200E38F08AF CSD : D00E00320F5903FFFFFFFFEF9640002F eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 15938355200 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 256 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 016G8B Product Rev : 0.0 Product SN : E38F08AF Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010030313647384200E38F08AF_10E333BA.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
