09-26-2014, 17:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Lumia 822 RM-845 Bricked 20:46:56 : Please wait upto 15 Seconds for SW Reset 20:47:17 : Version: 1.1.1.3 20:47:17 : Product Code: 059P3Z8 20:47:17 : Module Code: 0205158 20:47:18 : Continuing Previous Boot... 20:47:18 : Please wait upto 30 Seconds for Boot Re-entry 20:47:43 : 20:47:43 : Boot Flash Mode Successful... 20:47:44 : Buffers Flushed OK... 20:47:44 : 20:47:44 : Phone Info Query Start... 20:47:44 : Blocks Returned: 0x07 Blocks 20:47:44 : Block ID 0x01 :00241000 20:47:44 : Block ID 0x02 :00240000 20:47:44 : Block ID 0x03 :01DB0000 20:47:44 : Block ID 0x05 :Nokia.MSM8960.P5219.3.2.1 20:47:44 : Block ID 0x0D :0001 20:47:44 : Block ID 0x0F :0301010100000101FF 20:47:44 : Block ID 0x10 :01001F0000 20:47:44 : Checking SD Card Size... 20:47:44 : Card Size: 0x00000000 20:47:44 : Checking Platform Security Status... 20:47:44 : Platform Secure Boot Status: Active 20:47:44 : Secure FFU EFUSE Status: Active 20:47:44 : Debug Status: Active 20:47:44 : RDC Status: Not Active 20:47:44 : Authentication Status: Not Active 20:47:44 : UEFI Secure Boot Status: Active 20:47:44 : Checking Secure FFU Mode... 20:47:44 : Secure FFU Mode : 20:47:44 : Query Flash App Information... 20:47:44 : Flash App Information: 020112020200 20:47:44 : UEFI App: FLASH APP 20:47:44 : Flash App Protocol Version: 1.18 20:47:44 : Flash App Implementation Version: 2.2 20:47:44 : Query ROOT KEY HASH... 20:47:44 : ROOT_KEY_HASH: A0AE29AC24C843250D2DD0FFD409A649B4E4A09ED3B1A78413 FB2B94B7476AAB 20:47:44 : 20:47:44 : Sending Image Signatures... 20:47:45 : Image Signatures Accepted! 20:47:45 : Erasing Data Partition... 20:47:45 : Data Partition Erased Successfully 20:47:45 : Fixing Partitions... 20:47:45 : Preparing Buffers for DATA LOOP... 20:47:45 : Allocating System RAM OK! 20:47:45 : Start Sending DATA BLOCKS... 20:47:48 : ERROR: DATA BLOCK REJECTED at 0x01AA0000 20:47:48 : Check your Flash File and Phone Connection 20:47:48 : ERROR: Flashing Failed! Completely Dead . only Qualcomm HS Driver ... |
09-27-2014, 19:02 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Aamir_Zia Your flash file is probably corrupted or your phone is probably low battery. So charge your battery using external charger (because dead Lumia Phone cannot charge battery). When your battery is over 3.70v, if it is lower, then charge it still. After Battery is charged, try to flash it again. If still "Qualcomm HS Driver" then it means you need to FIX BOOT via eMMC TP. Files you need are here: LUMIA_822_RM-845_BIG_BOOT_3051.40000.1352.0042.mmc B.r. |
10-09-2014, 13:11 | #5 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | 16:57:27 : ================================================== ==== 16:57:27 : Loading ATF MMC File... (Please Wait) 16:57:27 : ================================================== ==== 16:57:27 : 16:57:27 : MMC File Version: v11.30 16:57:27 : MMC File Author: DE03C44B9EAB09A614A3EC72 16:57:27 : Date Created: 16/09/2014 (dd/mm/yyyy) 16:57:27 : Description: Lumia 822 RM-845 BIG BOOT - [3051.40000.1352.0042] 16:57:27 : 16:57:33 : Current Partition: Partition 1 16:57:33 : Start Writing Blocks... 16:57:33 : Writing Blocks Done! 16:57:33 : Current Partition: Partition 2 16:57:33 : Start Writing Blocks... 16:57:33 : Writing Blocks Done! 16:57:33 : Current Partition: Partition 3 16:57:33 : Start Writing Blocks... 16:57:36 : Writing Blocks Done! 16:57:36 : Current Partition: Partition 4 16:57:36 : Start Writing Blocks... 16:57:54 : Writing Blocks Done! 16:57:54 : Current Partition: Partition 5 16:57:54 : Start Writing Blocks... 16:58:07 : Writing Blocks Done! 16:58:07 : Current Partition: Partition 6 16:58:07 : Start Writing Blocks... 16:58:08 : Writing Blocks Done! 16:58:08 : Current Partition: Partition 7 16:58:08 : Start Writing Blocks... 16:58:21 : Writing Blocks Done! 16:58:21 : Current Partition: Partition 8 16:58:21 : Start Writing Blocks... 16:58:29 : Writing Blocks Done! 16:58:29 : Current Partition: Partition 9 16:58:29 : Start Writing Blocks... 16:58:30 : Writing Blocks Done! 16:58:30 : Current Partition: Partition 10 16:58:30 : Start Writing Blocks... 16:58:52 : Writing Blocks Done! 16:58:54 : Current Partition: Partition 11 16:58:54 : Start Writing Blocks... 17:01:35 : Writing Blocks Done! 17:01:41 : Current Partition: Partition 12 17:01:41 : Start Writing Blocks... 17:04:42 : Writing Blocks Done! 17:04:42 : 17:04:42 : 17:04:42 : Perform Firmware Update via USB Cable. |
10-09-2014, 13:48 | #6 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | ================================================== ==== Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset Version: 1.1.1.3 Product Code: 059P3Z8 Module Code: 0205158 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 01DB0000 Block ID 0x05 : Nokia.MSM8960.P5219.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020112020200 UEFI App: FLASH APP Flash App Protocol Version: 1.18 Flash App Implementation Version: 2.2 Query ROOT KEY HASH... ROOT_KEY_HASH: A0AE29AC24C843250D2DD0FFD409A649B4E4A09ED3B1A78413 FB2B94B7476AAB Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:05:56 |
