06-28-2016, 10:17 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | lumia 822 writing emmc error! R1b Timeout Error! Need to Repair " Error : Unable to find a boot loader option. Press any key to shutdown " flashing log......... Code: 12:06:57 : ====================================================== 12:06:57 : Windows Phone 8/8.1/10 Lumia Flasher 12:06:57 : ====================================================== 12:06:57 : 12:06:57 : If the Phone is ALIVE 12:06:57 : 1. Power On the Phone and Connect it to the USB Port 12:06:57 : 12:06:57 : If the Phone is DEAD 12:06:57 : 1. Connect Phone to the USB Port 12:06:57 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 12:06:57 : 3. Wait until the Phone Vibrates Shortly... 12:06:57 : 4. Stop Pressing the Buttons... 12:06:57 : 12:06:57 : If the Phone is DEAD BOOT 12:06:57 : 1. Connect Phone to the USB Port 12:06:57 : 2. Install Correct Drivers: 12:06:57 : "Nokia Emergency Connectivity" Located at: 12:06:57 : 12:06:57 : F:\Devices Setup\ATF\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ 12:06:57 : ====================================================== 12:06:57 : 12:07:18 : Nokia Phone Info Mode Initiated... 12:07:18 : Please wait upto 15 Seconds for SW Reset 12:07:18 : IMEI: 354599052604223 12:07:18 : Version: 1.1.1.3 12:07:18 : Product Code: 059P714 12:07:18 : Module Code: 0205158 12:07:18 : 12:07:18 : Continuing Previous Boot... 12:07:18 : Please wait upto 30 Seconds for Boot Re-entry 12:07:20 : 12:07:20 : Boot Flash Mode Successful... 12:07:20 : Buffers Flushed OK... 12:07:20 : 12:07:20 : Phone Info Query Start... 12:07:20 : Blocks Returned: 0x07 Blocks 12:07:20 : Block ID 0x01 :00241000 12:07:20 : Block ID 0x02 :00240000 12:07:20 : Block ID 0x03 :00000000 12:07:20 : Block ID 0x05 :Nokia.MSM8960.P5219.3.1 12:07:21 : Block ID 0x0D :0001 12:07:21 : Block ID 0x0F :0301010100000101FF 12:07:21 : Block ID 0x10 :01001F0000 12:07:21 : Checking SD Card Size... 12:07:21 : Card Size: 0x00000000 12:07:21 : Checking Platform Security Status... 12:07:21 : Platform Secure Boot Status: Active 12:07:21 : Secure FFU EFUSE Status: Active 12:07:21 : Debug Status: Active 12:07:21 : RDC Status: Not Active 12:07:21 : Authentication Status: Not Active 12:07:21 : UEFI Secure Boot Status: Active 12:07:21 : Checking Secure FFU Mode... 12:07:21 : Secure FFU Mode : 12:07:21 : Query Flash App Information... 12:07:21 : Flash App Information: 020112020200 12:07:21 : UEFI App: FLASH APP 12:07:21 : Flash App Protocol Version: 1.18 12:07:21 : Flash App Implementation Version: 2.2 12:07:21 : Query ROOT KEY HASH... 12:07:21 : ROOT_KEY_HASH: A0AE29AC24C843250D2DD0FFD409A649B4E4A09ED3B1A78413FB2B94B7476AAB 12:07:21 : Query PUBLIC ID... 12:07:21 : PUBLIC_ID: 1C27FB6C60E17EB7851C71DB292341C73DD1395F 12:07:21 : Query eMMC Info... 12:07:21 : EMMC Manufacture ID: 00 12:07:21 : EMMC Product SN : 00000000 12:07:21 : EMMC_SIZE: 0 Bytes 12:07:21 : Query Battery Charge Status... 12:07:21 : BATTERY CHARGE_STATUS: 4% 12:07:21 : 12:07:21 : Sending Image Signatures... 12:07:21 : ERROR: Flash Signature Block REJECTED! (0x11068000000E00000000) 12:07:21 : This Flash File is NOT COMPATIBLE with this Phone. 12:07:21 : ERROR: Flashing Failed! scan emmc log Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1101003031364738420098CD23634FFD CSD : D00E00320F5903FFFFFFFFEF9640002F eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 15938355200 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 256 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 016G8B Product Rev : 0.0 Product SN : 98CD2363 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1101003031364738420098CD23634FFD.ext_csd Backup Directory: F:\Devices Setup\ATF\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ writing bigboot file.... Code: 14:04:32 : eMMC Test Point Connection Module 14:04:32 : ====================================================== 14:04:32 : ====================================================== 14:04:32 : 14:04:32 : 1. DO NOT USE THE PHONE"S BATTERY 14:04:32 : 2. Connect the Soldered TP Connections to ATF Box 14:04:32 : 3. Disconnect the USB Cable and Wait until the 14:04:32 : the ATF Software will tell you to Connect the USB. 14:04:32 : 14:04:33 : 14:04:33 : Interface Reset OK! 14:04:33 : eMMC Access Type: SECTOR MODE 14:04:33 : eMMC Supported Voltage Range: 14:04:33 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 14:04:33 : 14:04:33 : CID : 1101003031364738420098CD23634FFD 14:04:33 : CSD : 50004000000000200000000000000000 (CRC7 Fail 0xCF) 14:04:33 : ERROR: EMMC_SELECT_CARD FAILED (CMD7) 14:04:33 : Check your Test Point Soldering! 14:04:33 : 14:04:33 : eMMC Device Information 14:04:33 : Manufacturer ID: TOSHIBA 14:04:33 : Device Type : Embedded BGA 14:04:33 : Application ID : 00 14:04:33 : Product Name : 016G8B 14:04:33 : Product Rev : 0.0 14:04:33 : Product SN : 98CD2363 14:04:33 : Manufactured : January 2012 14:04:33 : 14:04:33 : Card Specific Data 14:04:33 : CSD_STRUCTURE : Version 1.1 14:04:33 : SPEC_VERS : Version 4.1/4.2/4.3 14:04:33 : TAAC : 0 ns 14:04:33 : TRAN_SPEED : 0 KHz 14:04:33 : READ_BL_LEN : 1 Bytes 14:04:33 : WP_GRP_ENABLE : NO 14:04:33 : WRITE_BL_LEN : 1 Bytes 14:04:33 : CONTENT_PROT_APP : NO 14:04:33 : PERM_WRITE_PROTECT: NO 14:04:33 : TMP_WRITE_PROTECT : NO 14:04:33 : 14:04:33 : Extended CSD Saved: 14:04:33 : 1101003031364738420098CD23634FFD 14:04:33 : Backup Directory: 14:04:33 : F:\Devices Setup\ATF\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 14:04:42 : 14:04:42 : ====================================================== 14:04:42 : Loading ATF MMC File... (Please Wait) 14:04:42 : ====================================================== 14:04:42 : 14:04:42 : MMC File Version: v11.30 14:04:42 : MMC File Author: DE03C44B9EAB09A614A3EC72 14:04:42 : Date Created: 16/09/2014 (dd/mm/yyyy) 14:04:43 : Description: Lumia 822 RM-845 BIG BOOT - [3051.40000.1352.0042] 14:04:43 : 14:06:13 : Current Partition: Partition 1 14:06:13 : Start Writing Blocks... 14:06:26 : R1b Timeout Error! 14:06:51 : R1b Timeout Error! 14:07:06 : R1b Timeout Error! 14:07:19 : R1b Timeout Error! 14:07:30 : R1b Timeout Error! 14:07:41 : R1b Timeout Error! 14:07:53 : R1b Timeout Error! 14:08:12 : R1b Timeout Error! 14:08:29 : R1b Timeout Error! |
07-07-2016, 02:20 | #4 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Same here dear i hope its no solution may be its boot protect but me not touch it extra because nokia have security i hope team will reply u soon |
