06-02-2014, 17:14
#1 (permalink)
Member: 1343862
Sonork: 1614324 Thanks Meter: 18 | lumia 900 after repair imei counters LOCKED HELP Quote:
Default language ID 0x380A
JTAG Interface Connected, S/N 0xF493FCB0
Resetting and Exploring JTAG chain...No Devices found in Chain!
Loading AFP (Please Wait)...OK
AFP revision 4, compiled 11/12/2013 10:38:00 a.m.
Phone Type : Lumia 900 RM-808, RM-823
CPU Type : Qualcomm MDM9200 (MODEM)
Storage TYpe: NAND 128MB
Fix Type : Repair Stuck at Logo Boot
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type RM-XXX
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
Resetting and Exploring JTAG chain...2 Device(s)
Device #1 ID 0x100590E1 IR7
Device #2 ID 0x203F10E1 IR4
Restore Boot...
Waiting for Device Connection 60 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...OK
Initializing Device...OK
Detecting ONFI #1 ID...MICRON MT29F1G08ABBDAH4, 128 MiB
Testing Device Memory...OK
Sending Flash Loader...OK
Bad Blocks Request...OK
Restoring Partition #1...OK
Boot Restore Done!
Assemble Phone and Start Normally
If Phone cannot Start, perform USB Firmware Update Procedure
Completed in 0h 0m 17s. Code Download Speed 326 KiB/sec.
AFP revision 3, compiled 23/09/2013 07:35:00 p.m.
Unlock Type : Read PIN and PUK Unlock Codes
Other Notes : Automatic Counter Reset (If Needed)
2. Always Disconnect the Phone BATTERY Flex Cable
3. Connect RJ-45 JTAG Cable to ATF Box
4. Connect USB Cable to Phone
5. Use RESET JTAG button to check the JTAG Connection
6. Click RESTORE BOOT button to Start Reading Unlock Codes
Waiting for Device Connection 20 second(s)...OK
Halting Core...OK
Retrieving Unlock Codes...OK
Service Provider Unlock Codes Found
Level 1 PIN: 99095320 ACTIVE
Level 1 PUK: 11485329 ACTIVE
Level 2 PIN: 75146542 ACTIVE
Level 2 PUK: 77458037 ACTIVE
Level 3 PIN: 54719095 ACTIVE
Level 3 PUK: 92919548 ACTIVE
Level 4 PIN: 55622023 ACTIVE
Level 4 PUK: 30939999 ACTIVE
Level 5 PIN: 38868031 ACTIVE
Level 5 PUK: 98539237 ACTIVE
Reading Unlock Codes Done!
1. Remove JTAG Connection and Assemble Phone
2. Insert SIM Card from different Provider into the Phone
3. Power ON the Phone
4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it
5. After Code is accepted, wait 30 seconds until Operator Signal Appears
This is PERMANENT UNLOCK... Flashing will NOT RE-LOCK PHONE
AFP revision 4, compiled 03/02/2014 02:05:00 a.m.
Fix Type : Restore Original IMEI
Halting Core...OK
Restoring IMEI 35193390557101...OK
Halting Core...OK
================================================== ========================== | After repair imei i cant unlock phone because doesnt ask for CODE, please help, i did everything, flashed, hard reset, repair EFS, unlock again... |
