02-03-2014, 19:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | LUMIA 900 cannot unlock service provider problem - [SOLVED] |
02-04-2014, 10:21 | #3 (permalink) | |
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | Quote: when i try 2 do as u said i found dat phone fail to power properly it only shows WHITE SCREEN n hanged there any help? | |
02-04-2014, 10:47 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, if only "white screen" and no Nokia logo or only "AT&T logo" after white screen. Both can be repaired with MODED Repair file provided by ATF Team. BR |
02-04-2014, 10:49 | #5 (permalink) | |
it is only white screen n no at&t logo. wich moded atf file will i use and how do i write d file plsssssss | |
02-04-2014, 11:15 | #10 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @TBOUY Lumias are cannot charge when they are dead. If nothing comes on the screen after 10 minutes, then remove battery from PCB and connect 5V directly to it. If you connect more than 5V, then say goodbye to battery. So connect only 5V, leave 5V for 10 seconds... After 10 seconds, check voltage of battery. It should be more than 4v.. If still less than 4v, then connect again 5V for another 10 seconds... etc.. repeat until you get above 4v and stable put back battery to phone. |
02-05-2014, 12:35 | #11 (permalink) | |
i ve done all d above now batt level is 4.6 but problem same | |
02-06-2014, 16:27 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @TBOUY You can repair anything with Lumia 900. Depend on what is wrong with your phone. Try first Lumia 900 Boot Repair via ATF JTAG. LUMIA_900_MODEM_REPAIR_BOOT - Download - 4shared |
02-06-2014, 16:29 | #14 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, write this file with ATFJ.exe v1.0.6: C:\AdvanceBox Turbo Flasher\Phones\BOOT_REPAIR\LUMIA_900_MODEM_REPAIR_ BOOT.afp After it, phone should boot properly and will be unlocked, too. BR |
