Lumia 900 error Data Rejected at SEQ 0x814 Lumia 900 flash error Code: |
No one have a suggestion? |
@unlock-tn Make sure you are flashing phone with correct rm-xxx type. Make sure phone's battery is fully charged or you will get error. BR |
The RM is correct battery fully charged :confused: |
orjınal cable usb okey |
Hello friends happened to me on a Nokia Lumia 530 RM-1020 will be that I have some hope with this device? ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... Version: 2.5.2.; Product Code: 059W349 Module Code: 0206004 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00748000 Block ID 0x05 : Nokia.MSM8212.P6134.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02021D023500 UEFI App: FLASH APP Flash App Protocol Version: 2.29 Flash App Implementation Version: 2.53 Query ROOT KEY HASH... ROOT_KEY_HASH: 6DF7F89E7A01F5B5DCB54754545B30B8B036C6BD294ACE42C8 B34A7D504D6183 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x21600000 Check your Flash File and Phone Connection ERROR: Flashing Failed! |
Problem solved after leaving the battery at 100% charge ..:D |
