05-30-2013, 14:12 | #1 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1844868 Status: Offline Sonork: 100.1624020 Thanks Meter: 6 | Lumia 900 error Data Rejected at SEQ 0x814 Code: If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ====================================================== Sending AMSS Certificate HASH: 6898A268F71233A06C3082728DB725A38679C21C Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) Status : AMSS WRITE SUCCESS Sending ADSP Certificate HASH: 6898A268F71233A06C3082728DB725A38679C21C Certificate Size: 449 Bytes Status : WRITE ADSP CERTIFICATE SUCCESS Sending ADSP Data Blocks (Please Wait for 25 Seconds...) Status : ADSP WRITE SUCCESS Sending MDM AMSS Certificate HASH: 6898A268F71233A06C3082728DB725A38679C21C Certificate Size: 447 Bytes Status : WRITE MDM AMSS CERTIFICATE SUCCESS Sending MDM AMSS Data Blocks (Please Wait for 25 Seconds...) Status : MDM AMSS WRITE SUCCESS Sending MDM DSP1 Certificate HASH: 6898A268F71233A06C3082728DB725A38679C21C Certificate Size: 447 Bytes Status : WRITE MDM DSP1 CERTIFICATE SUCCESS Sending MDM DSP1 Data Blocks (Please Wait for 25 Seconds...) Status : MDM DSP1 WRITE SUCCESS Sending MDM DSP2 Certificate HASH: 6898A268F71233A06C3082728DB725A38679C21C Certificate Size: 447 Bytes Status : WRITE MDM DSP2 CERTIFICATE SUCCESS Sending MDM DSP2 Data Blocks (Please Wait for 100 Seconds...) Status : MDM DSP2 WRITE SUCCESS Sending WPOS Certificate HASH: 6898A268F71233A06C3082728DB725A38679C21C Certificate Size: 1652 Bytes Status : WRITE WPOS CERTIFICATE SUCCESS Sending WPOS Data Blocks [BLOCK 1 0x00000000~0x00FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 90F66D2226D2E6119230F078C4D73339 ---------- : 7DC5E420183C8829710CA48A7DB2D1CF Status : WPOS WRITE SUCCESS [BLOCK 2 0x01000000~0x016573FF] Data Size: 0x00657400 Bytes SHA-256 : AC956A88B3829BD3218ADEFE6756FBD2 ---------- : 1DA441201E5C85530650B4D594AAAEB1 Status : WPOS WRITE SUCCESS [BLOCK 3 0x01697400~0x01FFFFFF] Data Size: 0x00968C00 Bytes SHA-256 : B2E9F3AF4244EF77651525EBCFB85AD8 ---------- : 677A17F0779F3CB144F234BAD5475DB3 Status : WPOS WRITE SUCCESS [BLOCK 4 0x02000000~0x02FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 16CBEC187CFA09082C41385C7D4C01C0 ---------- : 65DBBBD71410044C70F85DDFC091BC64 ERROR: Data Rejected at SEQ 0x814 Status : WPOS WRITE FAILED |
06-04-2013, 10:27 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @unlock-tn Make sure you are flashing phone with correct rm-xxx type. Make sure phone's battery is fully charged or you will get error. BR |
01-23-2015, 23:14 | #6 (permalink) |
Major Poster Join Date: May 2005 Location: Brasil,Ba
Member: 146001 Status: Offline Thanks Meter: 7 | Hello friends happened to me on a Nokia Lumia 530 RM-1020 will be that I have some hope with this device? ================================================== ==== Windows Phone 8/8.1 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... Version: 2.5.2.; Product Code: 059W349 Module Code: 0206004 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00748000 Block ID 0x05 : Nokia.MSM8212.P6134.1.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02021D023500 UEFI App: FLASH APP Flash App Protocol Version: 2.29 Flash App Implementation Version: 2.53 Query ROOT KEY HASH... ROOT_KEY_HASH: 6DF7F89E7A01F5B5DCB54754545B30B8B036C6BD294ACE42C8 B34A7D504D6183 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... ERROR: DATA BLOCK REJECTED at 0x21600000 Check your Flash File and Phone Connection ERROR: Flashing Failed! |
