12-22-2013, 21:25 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | lumia 900 flash error Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending AMSS Certificate HASH: 8D46D4B7D643AF3C506945E7DA6386CCAA23D980 Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) ERROR: Data Rejected at SEQ 0x160 Status : AMSS WRITE FAILED -------------- phone was working just reset phone.butt cant power on cant work key combinations for hard reset |
12-23-2013, 02:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | You need to "push" / "shock" the battery so that it will have atleast 4.2v coming out. You need to open phone and disconnect battery flex cable then connect 4.5v from regulated power supply to positive and negative terminal of battery's flex cable. You need to monitor status of battery every 5 seconds. Once battery is 4.2v by itself, you will be able to flash it properly. Almost all lumia phones with internal batteries have this problem. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-23-2013, 20:21 | #3 (permalink) | |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Quote:
HASH: 8D46D4B7D643AF3C506945E7DA6386CCAA23D980 Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) Status : AMSS WRITE SUCCESS Sending ADSP Certificate HASH: 8D46D4B7D643AF3C506945E7DA6386CCAA23D980 Certificate Size: 449 Bytes Status : WRITE ADSP CERTIFICATE SUCCESS Sending ADSP Data Blocks (Please Wait for 25 Seconds...) Status : ADSP WRITE SUCCESS Sending MDM AMSS Certificate HASH: 8D46D4B7D643AF3C506945E7DA6386CCAA23D980 Certificate Size: 447 Bytes Status : WRITE MDM AMSS CERTIFICATE SUCCESS Sending MDM AMSS Data Blocks (Please Wait for 25 Seconds...) ERROR: Data Rejected at SEQ 0x220 Status : MDM AMSS WRITE FAILED ------------ i recharge battery for two hours with external charger still same | |
12-24-2013, 21:41 | #4 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | today i make jumper battery with n8 board and charge for three hours,,, butt same result ERROR: Data Rejected at SEQ 0x220 Status : MDM AMSS WRITE FAILED |
12-24-2013, 21:57 | #5 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
Click Me | |
12-25-2013, 15:01 | #7 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | |
12-25-2013, 17:07 | #10 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | here is screenshot,,,,,, Imageshack - zaiq.png |
12-26-2013, 04:41 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @chand_gee Not sure what is wrong with your phone.... but you can write MDM sections via JTAG. Sending MDM AMSS Certificate HASH: 8D46D4B7D643AF3C506945E7DA6386CCAA23D980 Certificate Size: 447 Bytes Status : WRITE MDM AMSS CERTIFICATE SUCCESS Sending MDM AMSS Data Blocks (Please Wait for 25 Seconds...) ERROR: Data Rejected at SEQ 0x220 Status : MDM AMSS WRITE FAILED ------------ Is your phone WHITE SCREEN now? |
12-27-2013, 16:56 | #13 (permalink) | |
after flash and get this error its not working even no vibrate | |
