02-06-2014, 01:35 | #3 (permalink) |
Freak Poster Join Date: Jan 2010 Location: lima peru
Member: 1208243 Status: Offline Sonork: 100.1635080 Thanks Meter: 13 | team atf zzzzzzzzzzzzzzzzzzzzz please check my post http://forum.gsmhosting.com/vbb/f609...85/index7.html |
02-07-2014, 03:32 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @javsoft It is working. Just use brain. You will get no support here because as the update says: "USE AT YOUR OWN RISK" This is 100% working solution tested by many people. If you do not believe it, then stop using it. Very simple... This was not supposed to be released in the first place... So now it is released but will be ZERO Support. Just use your brain and help your self. |
02-07-2014, 18:29 | #6 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: ....
Member: 750419 Status: Offline Sonork: 100.1604828 Thanks Meter: 45 | Quote:
thanks for reply, i use because i have see good futher with this box . i need a concret solution 10000% working . if i post that have a problem is for solved not for blablabla is test. i will like to use this box and i sold so much box in my country because is a very good box and great solution. but if you sayme that use my brain good , i dont like to use a box that dont giveme suport and I run aside. | |
02-07-2014, 19:46 | #9 (permalink) |
Member: 750419 Status: Offline Sonork: 100.1604828 Thanks Meter: 45 | can solved with this file? http://forum.gsmhosting.com/vbb/f609...oblem-1773969/ |
02-08-2014, 16:36 | #11 (permalink) |
No Life Poster Join Date: Nov 2006 Location: turkey
Member: 384775 Status: Offline Sonork: 100.1605469 Thanks Meter: 159 | LUMIA_900_MODEM_FIX_EFS2 - Download - 4shared first write this modem part. later try imei repair. working. |
