03-10-2013, 20:00 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Age: 34
Member: 1078009 Status: Offline Thanks Meter: 12 | Lumia 900 TP problem i tried the whole weekend to downgrade my Lumia 900 to qualcomm... But i'm stuck at the following error: "Phone was NOT detected. Check green wire connection" And i did check the pin-8 connection. For me, it seems to be fine... I soldere like 100 times, always same error.... Do you have any suggestions? Anything special to look at? pls, i need help |
03-11-2013, 07:41 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | TP picture available at C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX Check the TP . Tips - TP cable wire must be in short length & not thin Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
03-11-2013, 08:06 | #3 (permalink) |
Member: 1078009 Status: Offline Thanks Meter: 12 | Hi there, thx for your answer! i soldered TP using this picture. But i used 0,1mm wire for every tp connection (as i did for Lumia 800, which worked fine). I'll try thicker cable for pin-8 connection Great support here, btw! thanks for this!! |
