09-04-2014, 12:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: romania Age: 40
Member: 631660 Status: Offline Thanks Meter: 139 | lumia 900 unlock problem?!? help ! JTAG Interface Connected, S/N 0xA....... Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 3, compiled 23/09/2013 19:35:00 ================================================== ======== Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 5, Access to Memory Not Completed! Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x100590E1 IR7 Device #2 ID 0x203F10E1 IR4 Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 8, Access to Memory Not Completed! phone is fully working...jtag connection perfect..locked to orange france |
09-04-2014, 12:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | 1. Connect RJ45 cable to ATF BOX, click Read Codes then connect USB cable to phone 2. Remove PCB from the back panel, then try Read Codes as stated in point #1 3. Make sure Battery and all other FLEX cables are disconnected too. BR |
